Your guess is as good as mine
Someone just made me aware of this thread, here's some updates:
1) We have bar mounts available to fit the stock Stark clamps and support with or without the phone mount.
2) Triple clamps are in the works, but no ETA. We had hoped to have them available over a year ago, but we've been absolutely slammed for a few years now and that doesn't leave much development time for new products... Some products have jumped ahead of the Stark clamps simply because of demand. I believe there's good demand for the Stark clamps, just not nearly as much as some of the other products we have in the works, so we have to be smart about the priorities! Hoping things calm down a bit and we can get back on the Stark clamps soon.
3) While more offset = less trail, and from that perspective should have less stability, that is typically not the case on a dirt bike. Some of that comes from how we define "stability" and some of that comes from the fact we're not analyzing shopping cart wheels. Dirt bikes are far more complex than a simple 2D trail model will predict.
"Stability" in the sense that the front end resists knifing and twitchiness can be increased by increasing offset (reduces trail) OR increasing rake (increases trail). They have similar effects on stability, yet opposite effects on trail... But they both increase wheelbase, and therefore weight distribution. This all gets really complicated when you throw in lean angle, the fact that the force at the front wheel is constantly changing throughout a corner, etc., but the consensus from LOTS of testing is that more offset = more stability (as defined above) at the expense of ease of cornering.
You might have a different experience rolling around the pits or low speed simple maneuvers, but at speed over a bumpy motocross track or outdoor course, it's a different situation. This is why you see short offsets on supercross and long offsets on outdoor motocross. Generally the faster the conditions (speed) and the faster the rider (skill), the longer the offset they run for more stability.
