Suzuki RM-E Build 2026
LM-Makes
Oakley, Ca
Hello all!!
New member here.
Joined because I have started my 2020 RMZ to RM-E conversion and wanted to post it up here.
So far:
2020 RMZ250 chassis
Electro an Co MX kit:
QS138 70h v3 motor
Votol contoller with E&C 28kw tune
Wiring harness to match from E&C
Surron throttle
E&C switch gear and volt meter.
I debated sourcing all the parts from the kit myself, but when it came down to it, it was more time effective for me to purchase the kit from electro and co. (It doesn’t hurt that Electrobrapp and I are friends, although I think I like him more than he likes me 😂)
On order:
2x 72v 65ah Amorge “CRF250” batteries.
3d modeling my own brackets (with a little jumpstart from @Dave Daum with the battery cage side panel. Also someone had the motor brackets posted here. But I can’t remember who.
I will try to update as my build progresses. I am not a big posting guy, but I’m gonna try.
Hello all!!
New member here.
So far:
2020 RMZ250 chassis
QS138 70h v3 motor
Surron throttle
On order:
It looks like we can ad the Suzuki to the list of frames that battery shape fits into.
Make sure your counter shaft sprocket is at the correct vertical height. It looks a wee bit high in the photos.
Lithium-king.com makes motor mounts, $150 for your bike. Text them with your measurement from bottom mount bolt center to swingarm bolt center. I bring a leg up the back to support the battery. I don’t like to have the battery touch the motor to transfer heat. I just ordered one yesterday for a 2009 KTM
I know that!
Why spend $150 when I can design and have them made for $10?
Battery isn’t directly touching the motor, though the bracket is. I’m not worried about that heat transfer. If anything the bracket will act as extra air cooling heatsink as it is aluminum.
No different than the tried and true E&C YZEMX that I have.
What’s the recommended distance from the swing arm pivot? And
What’s the recommended distance from the swing arm pivot? And height?
I recommend taking the motorcycle, placed on aevel surface, with the motor installed, and measuring the distances. Good rule of thumb is to keep the sprocket teeth as close to the swingarm as possible. Set the vertical position so the center of the counterpart sprocket and swingarm pivot are on the same plane. Hope this helps.
Update;
Shined up the frame a bit.
Mocked up the controller with my new bracket (3d printed of course)
My buddy got the battery box and motor brackets made up and I just gotta go pick it up from him. Then I can get it put together aside from the battery. (Sill 4-6 weeks out)
Kid who owned this bike before me didn’t take great care of this thing. Going to grease up all the bearings. The rear sprocket looks like a meth head’s teeth.
Coming out so far.
Got the battery bracket and motor mounts made up and installed. Some-how the top bolt for the motor was off. I was able to pivot the motor mount up and back to match up but meant I needed to re-design the motor bracket. Redesigned and just need to have my buddy re cut them. 🤘🏻
The controller bracket worked so flawlessly I forgot to take a picture. 😂🙃
One more thing, just visual observation but you motor sprocket appears to high relative to the swingarm pivot - do you have a way to compare to the position to the original motor.
Interesting - I have a 96volt build with the QS138 motor - my current gearing is 14:46 and it still over revs at mid throttle (which consumes more battery than it should) so have been trying to find a 15T front sprocket.
Really like your 3D printed modelling, my work was much less refined.
