Stark co. - Suggestion box
Good point!
They could make it look foolish while at it. A soundbox strapped to it, acentric motor to shake it etc etc. They can easily make 5 maps that have curves like gears. I'm planning to do that as soon as i get an EX. In the premium subscription you should be able to do that and i've been curious about that from the get go.
HP per wheel speed (that's what the Stark can simulate) maps are out there for some bikes. If you could link the HP output into a sound/shake box you could do some cool marketing stuff with that :ROFLMAO:
I am also kind of thinking you could make it seem real and basically put the critics in a spot where they are staring at a potential product that is everything they asked for. Maybe it would change their mindset. Could include a smoke machine and a VP race fuel sent dispenser. Really cover every base and see what the response is.
it already have haptic signal on the phone screen just so you know
I'm not sure you understand what haptic means. On every other bike I've ever owned, when you press the indicator switch, there is physical feedback - a click, snap, or something similar - that lets you know that, yes, you have successfully pressed the indicator button. That's haptic feedback. I don't have to look down to my dashboard to know that my turn signal is on because I felt the switch through my finger.
On the EX, there is no feedback, and because the indicator switch is so poorly designed, it's impossible to be sure that you've actually started signalling without looking down at the phone screen. Approaching an intersection is the most dangerous time on the road, and having to take my eyes off of what's in front of me to verify that I've hit the switch correctly, and then having to repeat if it didn't work the first time, adds unnecessary risk to riding in traffic, and is a problem that every other manufacturer has solved.
I assumed haptic signal was something else, i didn't think twice about it. You have a point, but I have to say that at least on my bike there is a click on the button. It's something they updated in the latest models because my previous Varg didn't have it. Now I feel like I've pressed the button correctly
Hold on, there's a high-tech solution to know if it's on or not without having to look at it: the blinkers noise.
So you mean they don't do that?
A quick search seems to agree with me. Also, none of the 7 motorcycles I've owned over the last 28 years have had a blinker sound that I can recall... though I'll admit I probably wouldn't remember clearly for the bikes that aren't currently in my garage.
Well it's true most blinkers are quiet on motorcycles but if you've ever changed your relay to go from filament bulb to LED, there are some aftermarket relays that do very audibly click.
Also 50cc and 125cc more often get that noise so just thought Stark could have done that, it's an easy fix. Plus technically the Varg EX is akin to a 125cc motorcycle (for rider license) 😁
When you make that buzzer loud enough to hear it through wind noise and the helmet, it'll be louder than the drive train.
A small haptic feedback motor near the left handlebar could do the trick without much noise but a crisp sensation in the handlebar.
I'd love to see the time without having to always back out of the app. I think they added a clock to the newer interface. I'm on the MX 1.0
Software update history and what has changed/been added.
Maybe not take so long to go into shut down(holding down both buttons)
Ability to update software via wifi where 4g isn't available. I'm not 100% sure how this works but it rarely seems to download updates at home where I have crappy cell service yet strong wifi.
Safety issue. When riding hard enduro I often put the bike in crawl to lock the rear wheel as I struggle to right the bike. But if you start sliding down hill you are LOCKED in crawl. They absolutely need to allow you to shift while moving. I make an attempt to always try and put it in a "gear" prior to jumping on the bike but this has almost got me injured a few times on some steep slippery hills where the bike just starts building speed with the tire locked up. One of those moments a clutch would be great.
