3D printed side panel repair part
Spam Assassin
So as most of us know our side number plates are prone to breaking, especially the right side. The outer plate breaks off the inner mounting lip/flange and unfortunately the inventory of right side panels that Liquid Performance had has now been exhausted.
The Problem
The fix I will describe consists of a 3D printed part that will serve as a new mounting point that you can fasten your broken off panel to.
Model is available for free download HERE
This part can be printed in two pieces and not affect the functionality (which is what I did on the pictured prototype). I uploaded both the one and two piece designs. The one piece design you will need to add supports, two piece all I did was add brim on my first attempt and it printed successfully. I printed a half scale model as a one piece but did not attempt the full scale one piece print. This example is of the right side only but both sides are available for download.
The Fix
On the two piece models, I added holes that you can dowel the two halves together using pieces of 1.75mm filament cut to 12mm long.
Now there can be multiple ways you could reattach the panel to the printed support (bolts, adhesives, etc.), but for the sake of my demonstration I bolted it on using button head screws. These “elevator screws” that I found on McMaster Carr might also make a good choice-
Screws, 18-8 Stainless Steel, 1/4"-20 Thread, 3/4" Long
The end result feels very rigid, perhaps too rigid but it’s a start. This will be a work in progress so please share your feedback here and I'll do my best to implement any changes to the design. Also, anyone who would like to try their hand at any "remixes", please do!
Side plates would be super easy to splash a mold and make out of fiberglass or carbon fiber. Haven't had the need yet, but if I do I'll surely do just that.
That’s a great idea - might suggest some industrial Velcro with adhesive backing to attach to the side plate. If you get the right stuff it’s really hard to pull apart.
Can you add these to a new side panel. Or only useful for a broken one?
These particular pieces would only work for a completely broken off flange. It would unfortunately take a whole new model to have it nest properly to reinforce an intact panel. If one were to offset all the surfaces inward the proper amount and add clearances for the little side panel rib/reinforcements it should be possible.
