- Lake Havasu City, AZ
I've shown some of the pictures of my conversion in other posts on here, but here is a little more. I started this build after having had my KTM 250F Electric conversion for quite a few years. I helped a buddy in Florida build his version of a 2014 YZ electric, but around the specs of the ALTA, so I was itching to build another electric also around the ALTA specs.
I wanted more HP, 50hp seemed like the number. More battery, so I copied the ALTA battery. I am at a different a different voltage, but 20S21P with Sony VTC6 cells, would give me 72V nominal 630A 63AH and about 4.5KW of battery. A bike with aluminum frame and better handling, so the 2008 YZ25F. Here is a recent picture.
I have literally 1000's of images, I recorded this build with a lot of pics. Here is a list of the main pieces I am using on this build ME1302 motor, Kelly 72701 Controller, battery mentioned above. A primary gear reduction under the cover in the picture of 1.5239 using gears out of a KTM 450SX, since I had these parts. ( 21 to 32 gears) I used 3 gears out of that gearbox and the output shaft for my jack shaft. This has worked out quite well, but I am going to have it built by a machine shop from start to finish. This is a prototype that I put together with the help of various machine shops, and my own tools. You may notice that my aluminum welding is not professional grade.
I wanted to have the batteries easily replaceable , which I have accomplished. I have 3 packs 20S7P 210A each. Each pack has it's own BMS and own 10A charger port. I use 3 ea 10A chargers for a total of 30A at 110VAC.
In the picture above you see the cover for the right battery which comes off with 2 Dzus fasteners. In the Airbox you can see a little of the battery box behind the shock reservoir.
I built the 3 battery packs myself, and I have many videos of that build. So far the packs are holding up real well. I'm getting about 195A out of each pack. We went on a 15 mile desert ride ( I live 2 blocks from the desert here in Lake Havasu City, AZ) over the holidays, with a lot sand washes, and the battery was still at 75V which is about 60% battery left.
The controller has been a learning process. Kelly has helped, but it is typical Chinese poor manuals, and equal info in the email train from them. But it works now. It seems like all the controller vendors aren't to enthusiastic about making an electric motorcycle. ASI seems pretty proprietary, Kelly has sketchy info and explanations. Sevcon don't seem to be reliable, and Curtis I don't know too much about yet, but my friend in Florida is getting a special one from them, but the current is slightly limited. The Kelly does seem to get me close to 600A. With their most aggressive MAP it is whiskey throttle crazy . With a tamer MAP the power comes on better with power later.
Here are a few more pictures and I'll post more later. This project took about a year. I retired in Mar 2020, and have been quarantined to my garage all year. It's been a great outlet for me.
