Alternative chainslider for MXR/EXR
wwmotors
Bavaria Germany
Due to the fact, that the front chainslider is no more availlable and the 3D printed lasts only a few hours, i built an alternative one: i put a 2cm longer screw in the footrestholder and put a teflon roll onto it. Looks very good after a few rides! Cheers
Bloak
Ontario, Canada
Another solution, attached drawing for chain slider bolt
bolt diameter of 14mm worked well on one bike and other needed to be slightly smaller 13.87mm....best to take measurement of old bolt for diameter prior to making
I've been using KTM # 79003053010 chain Sliding Kit Below Cpl.16
(also KTM bolt#0025080306 HH Collar screw M8x30 TX40 but may come with sliding kit 79003053010)
Been using this setup for about 4-5 years
  • bolt 14mm drw (1).PDF
