- Lake Havasu City, AZ
+1. Alta's solution was to add what I call a 'clutch-up burst' right before WOT in mode 4, where the power increased a lot with little additional throttle rotation. I've never been a clutch-guy, but it felt a lot like a clutch dump to me so maybe lots of racers would prefer it. Just another thing easily fixed by the user-programmable Stark throttle maps we'll likely never experience.![]()
After much playing with throttle "curves" I really don't believe in them. If you make one section of rotation less sensitive, the other becomes more sensitive. So you have made it better for one case, and worse for another.
I think that what @fsfs means is the problem shown in this picture, in which the original curve is supposed to be a straight line; probably not what we have in our bikes:Wow - could not possibly disagree more! My Alta's throttle map/'curve' #1 feels weak from 0 to WOT, while #4 is stronger everywhere and way better for me and my riding style in every case. Not sure what's meant by "sensitive", I think in terms of RW torque/hp at specific throttle-rotation percentages.
Unfortunately I don't and I have to point out that I just made those pictures to illustrate a concept, but apparently the power curve adjustment of the Varg will have rpms and power as variables instead of throttle position and power: just take a look at this picture at 8:13 here:Do you know of any editable ones online, to create our own map diagrams?
Are you sure Alta embedded this feature? Never noticed it.+1. Alta's solution was to add what I call a 'clutch-up burst' right before WOT in mode 4, where the power increased a lot with little additional throttle rotation. I've never been a clutch-guy, but it felt a lot like a clutch dump to me so maybe lots of racers would prefer it. Just another thing easily fixed by the user-programmable Stark throttle maps we'll likely never experience.![]()
