Change in the way Alta is advertising torque
Any theories why they are making a change from advertising the torque rating at the countershaft (after gear reduction) to actual motor torque?
All other manufacturers report the torque at the motor. The max RPM is about 14K, just like on the 4-stroke 250. Why they initially decided to report the torque anywhere else is unclear.
Perhaps 42 ft-lbs of torque did not sound very impressive when the bike has only 1 gear? This is probably why someone decided to multiply it by 3.5.
But even with the 34 ft-lbs of crank torque my MX, which is also geared up 12/45, was still called a "Torque Monster" today by a B-level rider. He also added that it is more powerful than a 450. He almost looped out on a small jump, LOL.
Mark911
Corona Ca
It doesn't matter what the motor is "rated" at, it's how they map the motor controller. The only way to determine that is on the dyno as Phil demonstrated.
Honcho
Brisbane, CA
We used to publish torque at the countershaft because that was the best way to compare to direct-drive electrics. The reality is most of our customers are not cross-shopping Altas vs other electrics - they're shopping vs gas bikes. Gas bikes measure torque at the crank so measuring our torque at the rotor, upstream of the gear reduction, makes for a much more direct comparison that more accurately reflects the what the bike will feel like relative to a gas bike. So the difference is which side of the ~3.5:1 gear ratio you measure the torque.
