I received a response back from Elcon.  They do provide the chargers for Alta.  With a CAN controlled charger the vehicle tells the charger what to do.  This is normally a voltage and current request so the BMS on the bike is communicating with the charger to tell it what it wants and the charger is communicating back to tell the bike it's status.  This is from the Elcon site.  " The charger expects to receive every second a message from the BMS with CAN ID 1806E5F4 and 8-byte data with the voltage and current requested.  If the charger doesn't receive a valid CAN message in 5 seconds, it stops charging until it receives a valid CAN message.  The charger sends out every second a CAN status message with voltage, current and status information".  So another, higher current/power, Elcon charger may work with an Alta, but it depends on what the bike ask for.  In my case with a EX, the standard charger is about 2700W on 240Vac which works out to a little less than 8A.  If the bike is limiting the current to 8A through the CAN commands it sends to the charger, it doesn't matter how big a charger I use, the charger will only give 8A because that is what the bike asks for.  If on the other had the bike tells the charger to give a higher current, say 20A, not unreasonable since the programmers know the size of the charger is the ultimate limit, the charger will give the lower of the charger limit or what is commanded.  In the case of a 5Kw charger, this would be the charger which will deliver about 14.2A at 350Vdc.  Does anyone know if a Alta fast charger will work, and charger at the higher rate, on a MX or EX that originally came with a standard charger.  If it does, then it means that the current request from the bike are at least at the higher power level (approximately 9.4A) of the Alta fast charger.
What Elcon doesn't provide is the charger to bike connector.  This is apparently put on by Alta after the charger leaves Elcon.
I hope this is somewhat clear.  I am not a programmer, but if you have a question, ask away and I will try and clarify.
