Very nice thank you for posting
No watch the video at 1.13I have the same question, did you re-use the foam?
Good points but have you seen anyone damaging the battery from a fall?I would not be putting that axp guard on my bike better off with the standard guard then add a few bits of rubber or plastic.
To be honest I just do not think the stark is the bike for the job, Stark pay taddy and the guy in the lumberjack shirt good money to make there bikes look good. The thing is they have the skill to keep the front wheel up to keep the battery away from smashing rocks etc, if they do get it wrong and smash the battery they will have plenty more in the back of the truck.
Us bunch of wobblers are much more likely to smash the battery on the ground, not a problem for a well designed bike with frame rails and a good strong sump guard.
I agree. I have a set of case covers ordered. Trying Endurohog Ebay. Brake pedal tip also broke very easy. I ordered left hand brake but with the option on keeping rear foot brake active. Varg OEM skid plate is garbage it broke just looking at a rock ledge.All that plastic and still no protection of the gear case cover for when you lay the bike over or hit something head on in a rock garden. The bottom protection looks great but what I ride my bike is constantly sliding down rock faces and being flipped around on hill climbs I didn't make. The bike needs to be protected on all sides!
No I have not but I have not been around any extreme enduro since the stark has been out. Stark made big efforts to keep weight down the first footpegs are a good example, as an educated guess I would say that the battery case is strong enough just to do what it needs to do.Good points but have you seen anyone damaging the battery from a fall?
I've seen cracked cases but nothing on the battery.
Installed a bunch of upgrades on my stark for enduro including:
- Tank bag Moskomoto Pico 1L
Thanks for the pics. How does it attach to your frame on the sides? Are those just zip ties attaching the strap to the frame?
Yes. Mosko moto has videos on their website.Thanks for the pics. How does it attach to your frame on the sides? Are those just zip ties attaching the strap to the frame?
Regarding the Cycra Probend hand guards:Installed a bunch of upgrades on my stark for enduro including:
- Hang guard Cycra Pro Bend
- Brake levers ASV
I'm using the standard Cycra 1-1/8" clamps on the handlebars.Regarding the Cycra Probend hand guards:
What type of bracket do you use at the inner ends?
And what model of ASV levers did you choose?
As I have already broken my first brake lever in two hours of riding, I understand that something has to be done. I have a pair of Cycra probends from earlier, but I cannot make the inner brackets to suit the Varg EX handlebar.
Any advice will be welcomed.
I think those are the champs I have available. However, when I tested them briefly, it seemed like the handlebar was tapering off to a smaller diameter at the place where it seemed natural to place any clamps. Did you modify the phone pad or something else to get the clamps closer together?I'm using the standard Cycra 1-1/8" clamps on the handlebars.
You always have to do some minor tweaking of the aluminum handguard bar to get everything lined up.
All 1-1/4" handlebars have taper from 7/8" diameter where the grips and controls are, but they will still clamp OK.I think those are the champs I have available. However, when I tested them briefly, it seemed like the handlebar was tapering off to a smaller diameter at the place where it seemed natural to place any clamps. Did you modify the phone pad or something else to get the clamps closer together?
