- Pennsylvania
I keep thinking these would be the ticket for Alta owners, so I’m thinking out load here for the sake of discussion.  Since our 240v generators here in the states are mostly all the large home backup power type, and since as Ray had mentioned the new fast charger only requires 16 amp draw on 240, then one of these smaller European inverter generators would seem to be the perfect choice for the sake of portability.  The only things I’m unsure of, which I’m sure Alta would be able to answer, is if the 50hz is a problem, and also this;
As I understand it, European 240V power is:
Hot: 240 V
Neutral: 0V
Ground :0V
And USA 240V power is:
Hot: 120V
Hot: 120V
Neutral/Ground: 0V
So if having 240v on a single leg is a problem, then the whole idea is shot down.
Oded might be able to shed some light on this also, as I understand his standard voltage is 220v...
Oded do you know what hz your power is over there and is there anything different about your charger? I’d take an educated guess that your power is 220v on one wire of a three wire plug then also.
Of course there is the cost issue of importing a European generator if it would even work.
Any thoughts?
Hot: 240 V
Neutral: 0V
Ground :0V
Hot: 120V
Hot: 120V
Neutral/Ground: 0V
Any thoughts?
