Exr rear brake light wire and connetion clip question
Slayer
South Chicagoland
Does anyone know the specifics on the connectors and where to get them along with some of the wire used in the rear brake system on the Exr? I purchased a generic pull type brake light switch and it uses the same connector as the as the stock brake wire. Looking to build a jumper to rig my LHRB. Thanks.
Slayer
South Chicagoland
Cycle terminal
Terminals-Connectors-Accessories
These folks sell the connectors, pins and tool you need to match the connectors on your Alta. Looks like they’re out of the office till 1/14/19.
Use the pictures to match your connectors up.
Thanks for the info, might have found them on Amazon, I will see when they arrive. I did get my rear brake light hooked up and working (temporary) and will post a full description once the rig is complete.
