Front Axle sizes
SF Bay Area, CA
Hi guys,
Just trying to confirm axle sizes on the MX (4CS) and MXR (AER48) forks. I believe the 4CS uses the older, larger 26mm axle, and the AER48 uses the smaller 22mm axle. Is that correct? Anyone know what the EX/EXR Explorer forks use?
Also, I see Liquid Performance has the following two front axles listed. The bottom one is for the AER. Hopefully the top one is for the MX. Can anyone confirm?
E-Bro
New Jersey USA
6802866-01 - Used on: MXR, EXR (AXLE NUT - 2902892-00 is used for this axle)
6800095-00 - Used on MX, EX and SM (AXLE NUT - 2900199-00 is used for this axle)
Thank you for posting this. Recently i purchased a set of AER forks without a axle. Currently my 2018 alta ex uses the 26mm axle. If i purchased a 22 axle with nut. Can i replace the bearings in my EX hubs to work with the smaller 22mm axle. Or do i need to go with a different mxr wheel set?
I am trying to eliminate spending more than the bearings and axle cost. To make these AER forks work on my alta.
E-Bro
New Jersey USA
I had figured this out. Realizing that i have 2 sets of different size spacers. Fixing my issue. Disregard my question
