Is there any reason I can run 10-40w oil in the varg?
Jocke_D
Sweden
I'm not that into oil chemistry that I can give you the full chemical/technical reason why not to do it. But to use oil that differs that much from the manufacturers spec sounds like a really bad idea. 10-40 is made for a different application.
MadpdXabbott
Silverlake, WA
10-40 Motor Oil is not the answer, for sure. But looking for something thinner may not be all bad.
I'm going to run 75-80 in my Varg after my first 5 hours.
SF Bay Area, CA
Use the proper oil for the specific application. You are comparing apple oil to orange oil here.
The SAE viscosity ratings for engine oil and gear oil are not listed using the same standard. They are designed for different heat ranges, and engine oil needs to function when mixed with gasoline and detergents while withstanding the higher temps in an engine.
To quote the Bel Rey website:
“The most common mistake is the belief that the viscosity of SAE 80W gear oil is much thicker than the viscosity of SAE 10W-40 motor oil. This is absolutely incorrect! A 10W-40 motor oil’s viscosity is actually similar to the viscosity of 80W gear oil, and the viscosity of SAE 10W-30 is similar to 75W gear oil.”
mike61
I bought a very expensive bike.
After 5 hours I changed 80ml transmission oil. The price - some Cents!
Some hours of using the same, 20 maybe, I have to check.
Why should I take any other oil?
Kurlon
Maine
I've still got some Silkolene 0w-20 from back when I spent WAY too much racing pitbikes... 20yrs old, but it's in a plastic container so should still be fine, right? :p
mbw479
Australia
Reason for the question was that I was talking to an agricultural mechanic and he told me about a recent recall on a popular slashers gearbox. It took the same 75-90w oil the varg used, but it was causing the slasher to stall out as it is too heavy until it warms up. After the recall they went to a 10-40w oil….
That said I won’t go against the recommended oil, I do know of plenty of examples where people have gone against manufacturers spec in motorcycles with success.
Foss
Vestal, NY
I honestly don’t think these gears get hot enough to worry, in my opinion. Remember the W implies Winter not weight.
It needs the GL-5 gear oil for types of gears in it from what I can see. There is very little oil actually in it. I am guessing most all the oil is coating the gears when it is running and the gears are not really running through the oil. Just get GL-5 rated is the most important. Could try this stuff. 75W85 GL-5 Gear Oil
Just curious where you saw the "GL-5" requirement, is that in the owner's manual?
MadpdXabbott
Silverlake, WA
page 32, "SAE 75w-90 gear oil." The GL5 info was from Forum member in contact with Stark support, as I remember it..
07.019.06 CHANGE GEAR OIL PDF, Under Tutorial & Technical says, "Synthetic gear oil 75W-90"
