Toom38
- Central Florida
I just had to swap motors in the Varg. On the first ride I took it to a small field just to make sure everything was good. After about 5 minutes at upper 80's air temp, I got a warning on the dashboard stating an issue with the water pump. The water pump is running. Water is circulating thru the radiator and I loosened the coolant drain bolt on the motor to check for coolant. I did prime the pump according to Stark's video, twice. So I'm stumped. What am I missing? What else can I check? Does anyone know where the temp sensor is located? The first time I powered up the bike I did have a flashing magenta light so it did do an update of something. Any suggestions? Thanks.
