LED light options
schwankl
utah
I think Rashid's setup is only for MX(R) ... If you are upgrading the EXR light no need to crimp anything - the squadron sport plugs into the dual sport dimmer, which plugs into the existing 3 wire plug. There are different types of squadron sport lights tho. Rashid linked to the KTM version - for simple, do not have to remove existing lighting bracket, plug-in EXR upgrade I used these:
- Baja Designs (make sure its the DC powered version)
- Baja Designs
@schwankl as I said I can use on all bikes which have the harness already installed. I did use the KTM light mask which Baja does have pinned differently.
(Also this does remove the Alta specfic lighting bracket, with Bajas specific setup, which is common on most dual sport setups)
