@Jayfox911 this is what I ended up using to get the squadron sport to work:
x1 Baja Designs Squadron Sport LED headlight:
Baja Designs
(The DC one will work for our setup)
x1 Baja Designs, Dual sport Dimmer Harness:
Baja Designs
(This will allow you to pigtail from the Alta wiring harness headlight connector to a Delphi weatherproof connector)
I also asked Baja Designs to send me a set of Delphi weather-pack pins and connectors.
https://www.amazon.com/Delphi-Completed-Circuits-Weatherpack-Waterproof/dp/B075M2FL3W/ref=sr_1_3?crid=2GUS7KKD68UQQ&dchild=1&keywords=delphi+weatherpack+connector+kit&qid=1596383873&sprefix=delphi+wea,aps,212&sr=8-3
The connector on the squadron sport is a KTM 4-pin connector. Needs to be de pinned and crimped w/the new Delphi pins.
This is the end on the headlight which needs the new connector as the one on the dimmer harness is already there.  Once crimped, then connect it to the Alta harness and it will fire up! Complete with highbeam/lowbeam action.
