moto mutt
- spokane wa
I bought a new ktm clutch master cyl 10 mm from RMATV. there seems to be some controversy over 10mm vs 9 mm pistons. ktm went to the 9 mm for a lighter clutch pull. and while true a smaller piston produces more pressure. on a single piston rear caliper I don't think a mortal could note the difference in braking. bigger piston should make brake application less lock up more progression. a new rear master cylinder insert from clake in Australia. I have a new custom made very high quality hose as well. all "o" rings & seals. this allows you to retain both right brake pedal and the left brake on the handlebar left side. asking $220 with free shipping in the lower 48 states
