lights
erSitzt
I have Circuit hand guards, they fit okay (with rear brake on the handlebar).
I tried Acerbis too, but they fit a little less good..
Difference between the two variants, Circuit mount goes below, Acerbis on top.. i can post a photo later if you like
Raindog
WNC
The tail light is Magicshine SeeMee300 with a motion sensor that throws a brake light when it senses deceleration, perfect for regin. The headlight is a Magicshine Monteer 8000S, brighter than the sun but infinitely adjustable through the bar mounted switch.
I have the battery for the headlight mounted on the frame, the tail light is a self contained unit.
Bernardo
The oem light from the EX dazzle other driver on the road.
they are set to high
Any ideas?
It cant be adjusted i think.
There is a single screw which looked to me that it might adjust the level of the beam (i'm not 100% convinced it does or doesn't do this). I turned it a lot in both directions, in the end I found the top of the light beam on my garage wall had reduced by a minor amount, maybe 10cm or so.
Bernardo
thanx and yes.
there is an adjustment screw at the lower end of the electronic part of the headlight.
it can be seen when dismounted.
a plastic one. the whole inner part, reflector included, move up and down.
