lights
erSitzt
I have Circuit hand guards, they fit okay (with rear brake on the handlebar).
I tried Acerbis too, but they fit a little less good..
Difference between the two variants, Circuit mount goes below, Acerbis on top.. i can post a photo later if you like
Raindog
WNC
The tail light is Magicshine SeeMee300 with a motion sensor that throws a brake light when it senses deceleration, perfect for regin. The headlight is a Magicshine Monteer 8000S, brighter than the sun but infinitely adjustable through the bar mounted switch.
I have the battery for the headlight mounted on the frame, the tail light is a self contained unit.
It cant be adjusted i think.
There is a single screw which looked to me that it might adjust the level of the beam (i'm not 100% convinced it does or doesn't do this). I turned it a lot in both directions, in the end I found the top of the light beam on my garage wall had reduced by a minor amount, maybe 10cm or so.
