Don Thuren
- Bend, Oregon
Got my(amazing BTW!!!) MX Tech Lucky cartridges installed a few weeks ago, and they are SO good, they really made the OEM rear rear shock tune just feel even more terrible.
Using Silkolene RSF 2.5 the first tune was too soft and rebound was too fast, so here is the 2nd tune to adjust. I'm 200lbs and I really wanted to make a tune that works great with the OEM(softish) coil, and uses the HSC adjuster more as a broad range adjuster not so much just for "high speed". It worked out GREAT.
I experimented with a rebound tune that has a huge amount of HSR while a pretty light LSC, so a VERY steep curve. I like a more planted rear end feel.
Compression tune is designed to have a lot of mid speed support and as much of a reduction in true HSC as possible.
