Elite Motorsports
- Colorado
I received most of the components needed to install the MotoMinded Light Kit on our MXR!
Here is a quick...ish installation guide for the new light kit:
Step 1: Prepare the headlight and test fit brackets
Use the mounting hardware included with the kit to mount the MotoMinded/Baja Designs light in the mask.
Press the brake hose guide into place on the lower headlight bracket
Install the rubber dampers in the upper headlight/display bracket
You will reuse the tapered screws and aluminum washers from the bar pad (see later step) to mount the display to this bracket.
