MotoMinded Light Kit Install
Elite Motorsports
Colorado
I received most of the components needed to install the MotoMinded Light Kit on our MXR!
Here is a quick...ish installation guide for the new light kit:
Step 1: Prepare the headlight and test fit brackets
Use the mounting hardware included with the kit to mount the MotoMinded/Baja Designs light in the mask.
Press the brake hose guide into place on the lower headlight bracket
Install the rubber dampers in the upper headlight/display bracket
You will reuse the tapered screws and aluminum washers from the bar pad (see later step) to mount the display to this bracket.
Step Two:
Remove the bar pad by clipping the two zip ties and carefully move the display out of the way
Then remove the number plate to gain access to the wiring and clip the cable ties holding the display wire in place
disconnect the display wire by carefully lifting the tab and pulling the connector apart
Now you can remove the screws and washers holding the display on the bar pad. You will reuse these later
Resue the mounting screws and washers to attach the display to the upper bracket.
Remove the four screws in the front fender and take the fender off
Remove the stock fender bracket
Now install the lower headlight bracket with turn signals
Install the upper headlight bracket
reconnect the display
Use included zip ties to secure the cable in place
Mount Horn to the center of the top triple clamp
Remove the seat bolt with an 8mm socket
Now remove the mounting hardware for the seat pan (the lower screws have bushings that need to stay with the screws!)
I like to reinsert the screws into the fender for safe keeping. Mounting the hardware in the fender helps me keep track of the bolts and spacers while I am working on other things.
I placed electrical tape on the turn signal wires to help move it through the frame. position the wires under the frame cross member and out the back towards the seat (see photos).
Position brake cable as shown
Connect tail light harness
connect headlight switch harness
