Don Thuren
- Bend, Oregon
Just unplugged all 3 connectors from the DCCP at the same time, and Negative isolation KOHMS still low 200's...
Code 33 on MT, and MT notes very low number 230-260 KOHMS negative isolation..
Weird thing is if the bike sits for a while and I key-on MT will be 260 KOHMS, then cycle the key again 255 KOHMS, cycle again and 250 KOHMS, again 240 KOHMS.... It keeps going lower as I cycle the key over and over....
I unplugged the DCCP harness that connects to the charger, and no change on KOHMS.
Sweet thanks guys!
Mark I'll try reloading the firmware that makes sense to at least do that.. I want to say that when I bought this bike the guy told me that the Alta dealer said the charging issue popped up right after doing a firmware update, or something...
Datadog I pulled apart, inspected, and taped up the DCCP harness while in there, and all seemed good. Also, it seems like the bike turns on fine with it completely unplugged to test that as a source of the problem.
