So the take away from this thread, so far, is the same as from every 'range' thread I've ever read for an EV dirtbike (Alta, KTM Freeride, Surron X, Surron Storm, Zero FX, etc.). Ha. That is that every trail rider has greatly different preferred riding speed, outdoor temperature, elevation gain/loss, and surface firmness and that makes it very hard for anyone to predict what range another rider will get. In the very small sample size of this thread alone, there are Alta trail riding ranges from 8 miles to 50 miles (80km). I image the wide range variation will be the same for the Varg once orders are fulfilled and riders get them out on the trails.
That being said, based on the sliiiiiightly larger battery capacity, design features to improve efficiency and also based on some of the test rider comments, I expect the Varg to get better range than the Alta for any given rider riding the same way on the same terrain. How much more is the question that no one can answer until the demo bikes hit the ground summer 2022 and orders start getting fulfilled fall or winter of 2022.  Will it be an improvement of 3.5% (which is approximate battery capacity increase), 10% (due to both battery capacity increase and motor efficiency increase) or more? I don't think anyone can predict, but fun to speculate.
For all the reasons mentioned above, once the real world range tests do come out, realize that those tests will be different rider speeds, temperature, elevation changes, and surfaces and leave the readers/viewers trying to deduce our potential range by comparing theirs and trying to adjust for our riding parameters.
As for the Alta to Varg range comparison, I'm also curious on if there is a percentage improvement and if so, how much, but the only meaningful way to get valid comparative data will be for the tester to run a specific trail on an Alta then run it on the Varg the same day. Even the same rider but a different day (temp, riding style) and different trail/terrain wouldn't give good comparative data, unfortunately.
