Phone app did not record my ride
mlbco
Sunnyvale, CA
I have a new bike and did my first rides today. I did 2 rides in the session and shut the bike down between them. The second ride shows ride time but no GPS track or speed data. Anyone else have trouble registering each ride on the app?
Steve
What version of the app are you using?
I've had some trouble with the penultimate version (I don't recall the number): sometimes not all the data of each ride were recorded and the riding time was one possible missing piece of data. The overall hourage resulted to be less than the actual one.
Yesterday I used the bike with the latest app version available, i. e. the 1.0.135, and all the data was recorded.
mlbco
Sunnyvale, CA
Theo,
I'm running version v.1.0.135(290) which seems to be the latest. Some rides are recorded, some not. In the rides section one of my rides appears duplicated. Here is a screenshot of my rides with notes.
Is it possible that there was no continuous GPS reception for the ride with no GPS and distance data? Maybe if the receprion is interrupted for a significant time, the app, instead of showing incorrect data, will not show data at all.
Maybe the duplicate ride with no time nor distance was just a situatuion when the bike was engaged but only for negligible time and distance or without moving at all.
I personally had rides recorded with a significant distance and 0 time, which I can't explain without assuming there was a malfunction of the app.
mlbco
Sunnyvale, CA
I just enabled location permissions for Google maps on the Stark phone and now the Stark app seems to be working properly. I did 3 short rides in front of my house and all were recorded properly after enabling Google maps location.
mlbco
Sunnyvale, CA
I tested the bike later in the day and the problem still persists, the Google maps trick did not solve it! I sent a message to Stark and am waiting for a reply.
Steve
blbills
Utah
I too have issues with with the app sometimes not recording rides.
I've also noticed the ride length to aways be shorter (approx. 10%) than reality. I've compared it about a half dozen times to my independent fitness watch on my wrist and Onx running on the stark phone at the same time.
Not sure who's brainiac idea it was to put the GPS antenna (in the VCU) directly below a steel frame with a carbon fiber shroud over the top...
PsychoBunny
Southern California
I have other apps that are supposed to record rides and they sometimes have the same issue. Speedometer app is free and can be used at the same time but of course it's nice to have everything work. Just saying this happens sometimes with other electric vehicle apps like onewheel, lacroix, and evolve. One thing you can also do is like 15 seconds after you start your ride is see if it's recording.
mlbco
Sunnyvale, CA
Here is what Stark support says regarding this. I don't understand why 4G is required to record GPS data:
Thank you for contacting Stark.
If you have 4G data the phone should collect this information, it's possible that at the time you were using the VARG the 4G connection was poor, in which case the phone can't collect the information.
To do a quick test: No WIFI mode only 4G, open a youtube video and if you have 4G you will be able to watch it. If the 4G is working:
Can you please check the wireless charging module connector located behind the number plate inside the connectors box. Ensure it's clear of debris or oxidation. Also check that none of the wires going into the connectors feel loose. If the wires are loose, the vibrations while riding may cause the bluetooth connection between the Stark phone and the bike to be lost and possibly the reason why your rides are not being recorded.
Find more information about your new VRAG here:
Stark Future | Support
https://s3-stark-prod-public.s3.eu-...echnical_documents/Troubleshooting_FAQ_EN.pdf
Please let us know if there’s anything else we can assist you with.
Best regards,
Stark Future Team
Marshall G
Arizona
I hate the f'n thing. I can't stand fiddling around and pressing buttons on a phone to perform the most basic functions like recording mileage for a ride.
As mentioned above, one ride might have 4 or 5 'rides' recorded and none of them are accurate.
There's no trip function. Twice now, I've tried turn my GAIA app on in the background to record my ride, and then the bike wouldn't even run and required a hard reset. 4G required? Really?
Isn't the idea of a dual sport/ dirt bike to get away from it all?
I don't have one piece of accurate data on this thing. Hours, miles, track, nothing. Hell my 35 year old technology XR650L has the most accurate cable odo I've ever seen.
I really just want to see how much battery I have remaining, and how far I've gone - without all the brain damage. So far, not happy with the Arkenstone.
Any advice is appreciated. It should have the latest version. The bike is a week old.
Install Strava on the Arkenstone, start it logging a ride. You can then either split screen it with the HUD or let it run in the background and app switch to it when you stop.
Marshall G
Arizona
My GAIA GPS app should work the same way. But it seems like when I switch back and forth, it cancels the GAIA and it has to start all over. I guess I can try it with Strava. Seems weird that Strava (or GAIA) will work out there but the highly advanced Arkenstone ride app won't. WTF?
FreddyFugazi
BVT
The ride tracking is indeed terrible. However there does appear to be a proper odometer which is for some reason only visible from the dash screen. This information is not present on the ride stats screen and since the ride tracking is awful the ride stats screen is basically useless to me. While the ride tracking is unreliable, this odometer is accurate and what I've been using to keep track of mileage and battery consumption.
I expect this stuff to improve over time, but for now I will use Rever on my primary phone when I care about ride tracking.
Marshall G
Arizona
That ODO reading on mine is not accurate. I did a couple of 5 mile rides around the neighborhood, then I did a 40 mile ride in the desert. After all that my ODO read 33 miles. Then I did another 35 ish mile ride. It wasn't keeping up. Then, when I got home and recharged the bike, it now reads like 74 miles. I hope this thing doesn't need wifi to keep mileage.
On a bike where mileage and battery capacity are of paramount importance, you'd think they would have a simple trip 1 and trip 2 mileage keeper. My 2003 KTM had all that and more on its little 1" display.
FreddyFugazi
BVT
Oof that is troubling. I've only been out twice so far but it seemed accurate after the ride both times. Up to 58 miles here
Marshall G
Arizona
Stark hit me up with instructions to do a force shut down and restart on the phone. I did it, but it's still not recording properly. Worse, it doesn't like letting other tracking apps running in the background.
AbnormalWrench
Seattle, WA, USA
I hadn't been checking this, but it doesn't seem to matter much how good my phone reception is, the GPS tracking is horribly off on almost all of my trips. The maps are funny, it shows my path not following streets, just a lazy curved line from the start to the finish. The mileage is always way too low. I had two trips that I know were 50 miles total, but it says I only did 31 miles.
