Wheelsick,
Since you are the OP, how about you edit your first post with a table that is a running list with order number, order date, estimated delivery date, actual delivery date. Once you create the table, you can hover and insert rows above or below when others post info in the future. If the estimated delivery dates move (which I suspect they might, you can always add another column later called "Delivery Date - New Estimate".
Here is what I see above so far and you can copy and paste the entire table into your original post.
| Order Number | Order Date | Delivery Date - Original Estimated | Delivery Date - Actual |
| #aannnnn | 2021/12/14 | 2022/09/15 | - |
| #aannnnn | 2021/12/14 | 2022/09/24 | - |
| #CC12268 | 2021/12/14 | 2022/09/24 | - |
| #aannnnn | 2021/12/17 | 2022/12/16 | - |
| #aannnnn | 2022/01/02 | 2023/03/xx | - |
