Scott’s steering adapter
If you install the KTM triple clamps (+ KTM axle + KTM front wheel) you would have a variety of Scotts stabilizer mount options, but you would still need to figure the post mount setup. I can't remember if anyone here has figured out the post mount setup yet.
One of these days I'm going to look into it as I have my Scotts stabilizer and KTM mount bits just lying around.
Trialsman
Pittsburgh
You could try the unit that Ohlins have that presses into the steering head. The bearing then goes into the new piece and the front end assembles from there. I have had the Ohlins damper on my EXR for over a year now without any problems. I believe it was made for current KTM/Husky bikes.
Motoride
San Jose
Is Ohlins a two timer?
Scott’s indicates they merge with ohlins.
Wanted to use Scott’s So I can also use the damper with other bikes
