Thinking about making the plastics for alta
metallic88
utah
I give props to the designers at alta they did use almose every inch they could, I did get them a little closer so Itll be a little bit thinner in some areas.
metallic88
utah
Can you attach the stl or whatever the output is so that I can touch it up in blender and 3d print it?
I could but its only half of it atm, Im only using it for the special pieces alta made. you can buy them from liquid performance.
metallic88
utah
so i ordered some graphics to cover the frame from @fammxdesign, I'm toying with the idea of having the frame exposed, but I still havent found a design(i have over 10, frame covered ,ive tried ) i like or id have one printed to show.
metallic88
utah
My two cents is the shrouds should be relatively flat similar to an early 2000’s KX
with a conventinal frame that's possible, but with the contours of the alta frame flat is not an option with the frame covered(without the bike being super fat), and even without it not. Im going for less of a point than the stock shrouds though, but i also want it to look good. It'll have more of a ktm/honda style though i'm thinking, just to stay with the alta already having honda/ktm parts.
