using the Varg app on a non-Stark phone
Have you tried using tha app on a device which is not the Stark smartphone? Does it work? Have you noticed any conflict with the interaction of the Stark phone with the motorcycle?
I guess that it should be usable provided the Varg phone is not running the app or, even better, if it's turned off.
This could be useful in case you forget or lose the Stark phone and especially for those people who have removed the phone cradle.
The only possilbe hazard that I see is that if your phone has been hacked someone can affect the behaviour of the bike, but I think it's an unlikely event.
Impossible to install.
But I stopped then without checking why.
Maybe the phone or Android version, no idea.
The app is locked to this phone model. Don't know the details but the publisher (Stark) can lock what kind of phone the app is possible to download to.
I've just noticed that in the FAQ pdf file downloadable from the Support section of the Stark website they have written that only the Stark phone can connect to the Varg.
No wonder then that the app is locked to that phone model.
I was watching the Launch video from over two years ago and the app appears to have been MUCH more comprehensive than it is currently. They were talking about making changes on your personal phone and then moving the changes to the stark phone, and having an iOS app as well... As well as full navigation, air time, a ridiculous amount of adjustability (which I love)... I wonder if they'll just be releasing iterative updates.
I am sure it could be done if you just root the phone and spoof the device fingerprint to the one that was issued to you. There is also the option of emulating android using bluestacks. You’d have to replicate starks device on hand and test a lot assuring everything is offline. But the SIM might play a role in it as well. You’d need a phone with dual SIM compatibility.
But there are use cases probably in place if an unknow device heartbeats to starks servers you’d probably get a nasty gram… or a possible bricked device/bike, with a voided warranty. Many ways stark can enforce protecting their products.
I did at one point on a Pixel 8 Pro. I don't remember if I had to do anything beyond Play Store to get it. Getting it linked over Bluetooth worked, but it was a hassle to set up, and after that the Stark phone wouldn't connect any more. Getting the Stark phone reconnected was quite a hassle. I was hoping I could use my regular phone to check the battery level and such when I didn't have the Stark phone handy, but no dice. Seems like it's pretty much strictly one phone at a time.
I just installed the Varg app on my Fairphone 5, since the Varg phone for some reason has an Android version that's bound to Google. I don't know about you, but I mind having my location sent to Google on a regular basis.
What I did was dowloading the app as an .xapk file, then rename it to .zip and uncompress that. That left me with these guys:
Code:
com.stark.moto.apk
config.arm64_v8a.apk
config.en.apk
config.mdpi.apk
I uploaded them one by one: adb push config.mdpi.apk /sdcard/Download
The I installed SAI | F-Droid - Free and Open Source Android App Repository and marked all of the above files at the same time to install. That worked like a charm.
Then I logged in and connected to the bike. I had to restart the app to get it to use bluetooth properly. But now I have a completely de-googled Stark setup.
Code:
com.stark.moto.apk
config.en.apk
config.mdpi.apk
Google owns Android.
Android is still open source, so you can use it without having to send Google all of your personal information 24/7. The variant of AOSP I use is called /e/OS and does not have any proprietary Google software or services installed.
Code:
com.stark.moto.apk
config.en.apk
config.mdpi.apk
I am impressed, nice work! What is now your plan for mounting the Fairphone 5 to your Varg?
:)I am impressed, nice work! What is now your plan for mounting the Fairphone 5 to your Varg?
I've come to the conclusion that I don't really give the phone much attention while driving. I drive mainly enduro on pretty narrow trails, and have a comfortable setting on slot 1, so I don't keep track of the current speed, and I never switch program/level. So right now I'll just keep the phone in my pocket:)
How To Root Any Blackview Device Using Magisk [No TWRP Required]​
Here in this guide, we will provide you the steps to Root any Blackview device Using Magisk [No TWRP required]. Blackview devices are pretty much rugged outdoor smartphones with a tough body and bigger battery capacity. Rooting allows an Android smartphone user to work like a superuser. It offers administrator access to system settings and the app so that you can customize or change it according to your preference. However, the smartphone OEMs don’t provide rooting access by default to keep things simple with the stock version.
The Stock Firmware doesn’t come with too many options or customizations. Rooting your device may void your device warranty or brick your device easily. Meanwhile, it can be vulnerable as well. Additionally, you can install any Custom ROMs and mod files on your rooted device easily. However, the Custom ROM installation process requires bootloader unlocking as well.
So, if you’re using any Blackview device that runs on MediaTek CPU, then you should check out the full guide to enable root access on your device using Magisk. It won’t require Custom TWRP Recovery.
Advantages: Rooting​
  • Can flash Custom ROMs or Mods easily
  • Running special access-type apps
  • Extend Device Battery Life
  • Can free up internal memory by removing unnecessary files
  • Full of Customizations
  • Uninstall Bloatware
Disadvantages: Rooting​
  • Rooting will void your device warranty mostly
  • Improper rooting may brick your smartphone
  • Battery Heating, Occasional Reboots, etc may occur
  • Poor System Performance even after updating your device to the latest firmware
  • The device may become vulnerable
Supported Device List:​
Device Name
Blackview Tab 9Blackview BV9900 ProBlackview P10000 Pro
Blackview A80sBlackview BV9600EBlackview S6
Blackview BV6600Blackview A60Blackview P6000
Blackview A70Blackview A60 ProBlackview BV9000
Blackview A80 PlusBlackview A80 ProBlackview BV9000 Pro
Blackview BV5100 ProBlackview Max 1Blackview A10
Blackview A60 PlusBlackview BV5500Blackview S8
Blackview BV4900 ProBlackview BV5500 ProBlackview A7 Pro
Blackview BL6000 ProBlackview BV6100Blackview BV4000 Pro
Blackview BV6300Blackview BV9600 ProBlackview A7
Blackview BV5100Blackview BV9900Blackview BV8000 Pro
Blackview Tab 8Blackview BV9600Blackview BV7000
Blackview BV4900Blackview BV9700 ProBlackview P2 lite
Blackview BV9900EBlackview BV9500 PlusBlackview BV7000 Pro
Blackview BV6300 ProBlackview BV5900Blackview P2
Blackview BV5500 PlusBlackview BV9100Blackview BV6000s
Blackview BV6900Blackview BV9800Blackview BV6000
Blackview A80Blackview BV9600 Pro (2019)Blackview BV6000T
Blackview Tab 13Blackview BV9800 ProBlackview BV6000
Blackview BV7100Blackview BV9600 PlusBlackview BV5000
Blackview BV5200Blackview BV5800 ProBlackview BV5800
Blackview Oscal C80Blackview A20Blackview BV5800 Pro
Blackview Tab 15Blackview A20 ProBlackview BV9500
Blackview BV7200Blackview A30Blackview BV9500 Pro
Blackview A52Blackview BV6600EBlackview BV6800 Pro
Blackview A85Blackview BV6600 ProBlackview R7
Blackview Tab 6Blackview A95Blackview Tab 12
Blackview Tab 11Blackview A50Blackview Tab 7
Blackview BV4900sBlackview A55 ProBlackview A90
Blackview Tab 60Blackview BL8800Blackview A55
Blackview Tab 80Blackview BL8800 ProBlackview Tab 10 Pro
Blackview Oscal Pad 15Blackview BV8800Blackview A70 Pro
Blackview Oscal Spider 8Blackview Tab 8EBlackview Oscal Pad 10
Blackview BV6200 ProBlackview BL5000Blackview BV5200 Pro
Blackview Oscal S70 ProBlackview Tab 10Blackview BV9200
Blackview A96Blackview A100Blackview Oscal S80
Blackview Tab 11 WiFiBlackview Tab 8 WiFiBlackview Tab 5
Blackview BV8900Blackview Oscal Pad 60Blackview Tab 11 SE
Blackview Tab 12 ProBlackview Oscal Pad 70Blackview Tab 16
Blackview Active 8 ProBlackview Oscal C30 ProBlackview A53
Blackview N6000Blackview BV5300 ProBlackview A53 Pro
Blackview BV9300Blackview Tab 50 WiFiBlackview Oscal Pad 13
Blackview Oscal C70Blackview Tab 70 WiFiBlackview A200 Pro
Blackview Tab 18Blackview Oscal Tiger 10Blackview Shark 8
Blackview Oscal Tiger 12Blackview Oscal Pad 18Blackview BL8000
Blackview BL9000Blackview Mega 1Blackview Color 8
Blackview BL9000 ProBlackview BV8100Blackview Tab 16 Pro
Blackview Hero 10Blackview Tab 90 WiFiBlackview Mega 2
Blackview Active 10 ProBlackview Tab 9 WiFiBlackview BV8200
Blackview Tab 60 WiFiBlackview Shark 9Blackview Wave 8
Blackview Tab 60 ProBlackview Wave 8CBlackview Oscal Flat 2
Blackview BV6200 PlusBlackview Oscal Pilot 1Blackview Oscal Flat 2C
Blackview BV4800 ProBlackview Oscal Tiger 13 5GBlackview BV7300
Blackview Oscal Pad 90Blackview Shark 9 5GBlackview N6000SE
Blackview Oscal Elite 1Blackview Oscal Pad 5Blackview Oscal Pilot 2
Blackview Oscal Modern 8Blackview Tab 30 WiFiBlackview Oscal Pad 50 WiFi
Blackview Oscal Pad 7Blackview Oscal Pad 80 WiFiBlackview Oscal Pad 16
Blackview BV4800Blackview A52 ProBlackview BV5300 Plus
Blackview Oscal Flat 1CBlackview BV9300 ProBlackview Oscal Pad 6
Blackview BV8900 ProBlackview Wave 6CBlackview BV6200
Blackview Spider 8Blackview Active 6Blackview Active 8
Blackview Oscal S70Blackview Tab 7 ProBlackview Oscal C30
Blackview BV5300Blackview Tab 15 Pro
Steps To Root Blackview Device via Magisk​
  • Rooting may void your device warranty. Check properly before doing anything.
  • Sometimes, the rooted device won’t get official OTA updates properly. If your device gets frequent software updates then you need to think first.
Pre-Requirements:​
  • Charge your handset at first up to 60% at least before starting the flashing process.
  • Kindly make a full backup of your device before following the next steps.
  • A PC/Laptop is required along with a USB Cable.
Download Links:​
GetDroidTips will not be held responsible for any issue that occurred to your device during or after following this guide or flashing any file. Do it at your own risk.
Steps to Extract and Patch Boot.image using Magisk​
  • After downloading the Stock ROM, simply extract it on your PC.
  • Now, connect your Blackview device via a USB cable and copy the boot.img file only from the extracted folder to your device storage.
  • Open the Magisk Manager on your device. Select the Install option to choose the file.
  • Now, tap on ‘Patch Boot Image File’.
  • head over to the folder where you moved the image file earlier.
  • Now, wait for a couple of seconds and Magisk will start patching the boot image.
  • Once the boot image is patched, copy the ‘patched_boot.img’ from the internal storage and replace it in the same extracted ROM folder on your PC.
Now, follow the second step to flash the patched boot image file.
Steps to Install the Patched Boot Image on any Blackview Device​
Follow the link mentioned below for a full detailed guide on how to install a patched boot image on any MediaTek device.
Guide to Install Patched Boot Image on Spreadtrum Handset
Guide to Install Patched Boot Image on MediaTek Handset
You can also try using the ADB & Fastboot method to install the patched boot image file.
  • We assume that you have already downloaded the ADB & Fastboot tool from the link given above.
  • Next, you need to extract the ADB fastboot tool, and then move the patched boot image file to the same folder.
  • Press and hold the Shift key and right-click on the mouse to open the Command Window.
  • Then type the following command in the command prompt and hit enter:
fastboot flash boot patched_boot.img
  • For devices with an A/B partition system, type and enter the following command:
fastboot flash boot_a patched_boot.img
fastboot flash boot_b patched_boot.img
  • You need to replace the filename.img with the name of the TWRP Recovery IMG file that you have downloaded.
  • The flashing process will begin. Wait for a few seconds to complete the process.
  • Now, type the following command and press enter:
fastboot reboot
Steps to Verify Device Systemless Root:​
  1. Download the Magisk Manager app APK file > install it on your device and open it.
  2. Now, you need to verify the root. Go to the Status mode. If you see all options are green-checked, that means you have successfully rooted. It also means that you’ve bypassed the SafetyNet as well.
  3. That’s it. Enjoy Rooting!
Device Name
Pre-Requirements:​
Download Links:​
fastboot reboot
I googled so much! I never found that info. Instead I bricked my Varg Phone so not even the boot loader works 😅
Yea I mean this is for people who have a strong background in computers. This post was intended to lean on the possibilities of anything. So long users know what to do after rooting a device.
Just keep in mind stark may have ways to fingerprint behavior with rooting so know how to mask your tracks. This will void your warranty and if they suspect an intrusion they could brick the phone and bike. I would do this all in enclosed sandbox, remove the SIM and disable communications.
But this methodology could allow the end users to create backups and move system files to other devices. Also, you could manipulate system files like total hours ran on the bike… cough cough. The data is server side but there are still ways around this i am sure.
This is for educational purposes only and I shared it as a tool for people who have bricked their stark phones and need a way of backing it up and restoring it.
Bricking the bike would be a bit authoritarian. You bought the bike, it should be yours to do with as you please. I mean, I bricked my Varg phone, and i would lever expect them to replace it. It's quite obvious that's on me 😅
Yea i don’t know i mean i have seen this with Xbox’s and ps, especially with JTAGS and NAND bypasses for dev kits (xdk) lol. Whatever could be in the TOS I guess.
You guys also have the option to use Bluestacks which is an emulator.
