Varg EX - Indicator Switch Issue
EVMX
Just picked up an EX and my turn signal switch is very difficult to use. I have to push in on the switch and then awkwardly nudge it left or right - and sometimes that doesn’t even work. Is this normal behavior for this switch?
Bernardo
i have a similar behavier. not that bad but the switch is not reliable as
a turn signal should be. did some dry practice in the garage to get the best force- vector
to be applied on the knob…
brongle
WA
It's a terrible switch. You have to press it with minimal force and at a weird angle instead of directly left or right, and even then it has very minimal feedback with gloves on so you have to visually confirm. On mine trying to indicate left will hit the right indicator instead about 20% of the time. You do sort of get used to it over time, but still clunky compared to any other handlebar controls I've used. The last firmware update increased the amount of time the blinkers are on for (when using a short press) which I found was a nice usability improvement.
Kenorama
OREGON
Same issue here, pushing left the switch hits are a hard stop while right has a nice click and works. I just ordered a new unit from Lithium, arrived 2 days later and is notable better. Even the mode buttons feel better. Original mode buttons were constantly sticking in the depressed position.
That switch should be covered under warranty.
