Heating and cooling cycles requires airflow in and out, breathing.If you only let air out with a one way valve, air will find other ways in under vacuum, such as bearing oil seals, gaskets etc. Other substances such as dirt and water can follow the air breathing if you don't control where this happens.
It's a gearbox with an open breather tube.
And this is why I change my oil every Moto now. Doesn’t take a lot, and it isn’t expensive.One big difference between the breathers on something like a YZ250 vs the Stark is the anticipated internal temps. On a gas burning engine it is expected and desired that certain areas get up above the boiling point of water. This drives out moisture from the system via the breathers as you operate the bike. Cars rely on this as well, and it's a big reason why vehicles used for short trips tend to have worse service histories, if not driven long enough to get things up to temp, moisture builds up. Hybrids like my Jeep will even force engine use when there is plenty of battery if the oil hasn't seen good operating temps in awhile to drive out moisture.
Vargs don't get that warm internally, at least not intentionally, so I'd be a fan of a more proactive means of keeping moisture out if possible, or I'd be going to a much more frequent oil change interval when there is a chance of moisture ingress from washing, water crossings, operating in rain/muggy weather/etc.
Hey rayivers, I see in your signature that you own an Alta: does it have any problems with moisture in the gearbox? Does it have a breather hose?It is! Mine surely won't be, in one direction anyway![]()
I have been using this:While we're talking about Stark gearbox oil, does it need GL-4 or GL-5 oil? GL-5 is better for high wear situations like hypoid gears but is more corrosive to yellow metals. GL-4 suits spur gears but is less common these days - my local shop had none.
I checked with Stark support. Their answer: both API GL-4 and GL-5 oils can be used in the gearbox without issue.
Ya agreed. They do charge double for the synthetic like Lucas vs the non-synthetic regular brand which is also GL-5.The API oil specifications are tight enough that there's no meaningful difference in performance between the brands, no matter how much the oil companies spend on advertising to convince us that that oil is special.
I used whichever 75W-90 GL-5 oil came in the smallest size, coz a litre should last ten oil changes.
P | Stark Varg Display | Stark Varg -- General | 1 | |
S | Stark varg “tumbling” noise | Stark Varg -- General | 0 | |
D | Stark Varg Frame and Motor Protection | Stark Varg -- General | 1 |
