Magoo69
- Massachusetts
How’s the suspension since the re-valve?Agreed. Shipping my suspension out tomorrow to get it revalved. That's what we get for trying to use a moto bike for offroad.
What were your starting settings?Here is my situation:
• rider's weight in underwear: 74 kg/163 lbs
• suspensions setup: 75/80 kg
• use: motocross only
At the beginning, the suspensions felt stiff to me in every track.
Saturday at the track, at 8 hours circa it seemed to me that maybe they had softened a little bit but still not enough, so I softened them by turning the following clickers 2 clicks counterclockwise:
• fork compression
• fork rebound
• shock fast compression
• shock fast rebound
and they felt much better, maybe still a little bit on the stiff side but acceptable.
I cased some middle sized/big jumps and it didn't feel like they were bottoming out.
I will try these settings in other tracks, too,
Update: I drowned the bolt (literally) in wd40 overnight and the right hand side came out fairly easily, the left hand side is actually a sleeve that the bolt screws into from the right, it has to be undone opposite as it is a left hand thread. Bearing is greased now and it is back together.Has anyone removed the rear linkage bolt that runs through the swingarm? I removed both the end caps, then tried to undo the nut by holding both ends of the bolt with 17mm sockets on extensions, but the resistance to undo it was extremely tight so I left it in. It is the only bearing I haven’t greased on the bike.
They were all wet, now they are packed. The bolts and threads were all very dry, some were tight. They are all greased now too.Would you say that the bearings were well lubed originally?
I would start with Rebound adjustments. May need to turn in some.UPDATE: I just rode for the first time since Factory Connection did a re-valve front and back. I only ride single track, some flowy fast stuff and some rooty technical stuff.
I was looking for them to take some of the harshness out and make the Varg a little plusher. Well, they did that and then some.
PROS: It‘s like a magic carpet ride over the roots, logs and rocks. It’s definitely not harsh/stiff anymore. It’s very plush…it was very nice not to feel every little nook and cranny in the trails, BUT….
CONS; The Varg no longer has that planted feel it had. It no longer turns well at all. I was bouncing all over the place like a Pogo stick. It was darn near dangerous in the big woops. Traction on rough uphills was awful. It was almost impossible to keep the front tire in rutted turns and in straight ruts, it just didn’t track well at all. The front end was diving in and front traction wasn’t great.
The good news is I’m sure they’ll figure it out and make the proper adjustments to get it right. I think they went way too far on the plush side.
I can confirm, every joint needs to be re-greased. I took my swing arm off, removed all sleeves for the knuckle and the linkage and it was bone dry with a little nasty yellow grease; it wasn’t packed.Has anyone removed the rear linkage bolt that runs through the swingarm? I removed both the end caps, then tried to undo the nut by holding both ends of the bolt with 17mm sockets on extensions, but the resistance to undo it was extremely tight so I left it in. It is the only bearing I haven’t greased on the bike.
Yeah it is necessary, I am surprised Stark don't have a manual on this because it is a very common thing to do. Especially with the left hand thread, someone will get too keen and strip or break it eventually.I can confirm, every joint needs to be re-greased. I took my swing arm off, removed all sleeves for the knuckle and the linkage and it was bone dry with a little nasty yellow grease; it wasn’t packed.
Right, whoever is their supplier for the swing arm needs to rethink their strategy lol. They are adding bare minimum lubricant… and the grease they use is this crappy yellow smelly material which belongs no where near a bike lol.Yeah it is necessary, I am surprised Stark don't have a manual on this because it is a very common thing to do. Especially with the left hand thread, someone will get too keen and strip or break it eventually.
