revoltlution
Keep yer cool, don't get hurt, and never give up!
- St Johns, Portland, OR 97203
I'd like to power my helmet light from the rear light circuit. Anyone know the available wattage?
revoltlution has an EX or EXR (not an MXR) because he is talking about rear light circuit and front headlight (not aux light) circuits. The headlight circuit is designed to constantly power a 35w filament, but usually these circuits are capable of powering up to a 55w filament. The EX and EXR bikes have the aux light circuit like the MXR but it is used to power an automotive 194 type bulb that is mounted in the same enclosure as the headlight.Min to activate it is 4W and max is 40W.
More details here:
Alta MXR 2019 how to activate 12V electricity at the light aux conector behind the front number plate or find 12V output
Thanks for this info! I have the squadron pro coming in the mail. Looks like I need to change direction and order up the sport (and the connector kit)I have installed the squadron sport on an EXR and it works. When I tried the squadron pro it flashed and then went off - must be some programming limiting the power output. Also Baja Designs sells a 3 prong adapter that allows you to plug into the Alta wiring harness with no modifications
T | Stark Varg Rear Brake Disc Cover | Brakes | 2 | |
Lithium King QS138 Rear Motor Mount | DIY e-Motorcycles | 5 | ||
dirt in the stop bump of the rear shock | Suspension | 0 |
