Shroud screws
Scooter584
Council Bluffs, IA
Upper ("radiator") shroud screw is stuck in brass insert and the insert is spinning. Anyone have this happen and what did you do to get it out. I have pleanty of tools but just need a direction. I believe this has happened to me long ago on a Yamaha but I don't remember how I got it out. Any ideas would be appreciated.
Oh and I tried a heat gun, started to warp the plastic a bit and no luck.
Bionicman
E powertrain proponent
WA
I'd probably use my Harbor Freight drill bit kit to diagnally bore a very small hole through edge of plastic just touching insert install a screw to fix insert
then depending if screw is cross threaded or torqued use my Harbor Freight locking pliers to extract..
then reassemble with a very light torque with a liberal dose of JB Quik on insert....
You can remove the shrouds still attached to the black "delta wing". I had the same problem once, I ended up breaking the delta wing's plastic, and getting a new delta wing under warranty. Now I would be more careful. Drill out the bolt, if I have to.
The inserts pop out to the inside of the delta wing, not to the outside like many other inserts. So, drilling out the bolt is a viable option, if you want to remove the insert without destroying the delta wing.
Scooter584
Council Bluffs, IA
Thank you guys, ya I had the delta wing off with the shroud taking a quick look at it but didn't get a good look at the insert, good to know it pushes through instead of pulling out.
I don't think it's cross treaded...at least I didn't do it I haven't taken them off since I picked it up new so my guess is just froze up a little.
aremean79
Singapore
I am having the same problem too. I was going through the bolts the other day and realized that the top right shroud screws were over-tightened and now the insert will spin together with the screw. Let us know how u get it out when u do... Thanks!
revoltlution
Keep yer cool, don't get hurt, and never give up!
St Johns, Portland, OR 97203
I had the same problem... Tighten too much then the insert spun... It got a little messy getting the insert out :(
Have a few blown out inserts in the tail section too! Sheesh... Lately my mind is thinking about finding a solution to retrofit alternative plastics.
