- Lake Havasu City, AZ
Under a heavy load (WOT, Map 4) the MXR battery works better than the MX battery. It does not overheat, and the software does not start limiting your power with ~20% of the charge still remaining. So, in this sense, the MXR has a longer range. But in all other maps and under partial throttle conditions the range should be identical.
It is possible to ride around for 2 hours, no problem. You can cover 35-40 miles at an easy pace. But, unfortunately, I do not think there is a 2-hour race out there that is slow and also easy on the battery. Perhaps a downhill race??
