so there is the alta shroud stl(for anyone that wanted to print one), its smoothed alittle bit, and itll need a little bit of work if you want to print it.
ive been thinking of those(just haven torn it apart), I dont have a ex/exr so i cant do that. but my scanner has no limitations ive scanned whole cars with it and whole dirtbikes.@metallic88 i really appreciate you scanning the parts. Do you think you can scan the rear fender, subframe, shock mud flap, lower black plastic cover underneath the rear fender, and/or the rear tailight/license plate bracket for EX/EXR's? Or do you have some sort of size restriction on your scanner?
i tried to upload them but it says their too big.@metallic88 i really appreciate you scanning the parts. Do you think you can scan the rear fender, subframe, shock mud flap, lower black plastic cover underneath the rear fender, and/or the rear tailight/license plate bracket for EX/EXR's? Or do you have some sort of size restriction on your scanner?
heres a link to them, theyll need alittle work i didnt want to spend anymore time on them.
asfprts.zip
I think that 2006 Yamaha YZF shrouds May be the right size / configuration / shape etc.
I attached some pictures - would be willing to purchase a shroud off eBay and send it to you to try.
Can we see some pictures of bothmy 2013 kx450 are practically made for the alta with a little cutting. the ktm ones fit pretty good as well i just dont like covering the frame vents so i havent found a way i like it.
post #95 is the 2013 kx450 ones, i havent taken a pic of the ktm except before i cut it up post #86 but when i get time ill see if i can get a pic of the one i modified.Can we see some pictures of both![]()
I highly recommend against it because it gives a chance to the hose to rub against the harnesses.I see you routed your LHRB through the frame. Interesting choice.
wouldnt it rub against the coolant lines also, or maybe its ran lower?I highly recommend against it because it gives a chance to the hose to rub against the harnesses.
@metallic88 any updates?
also I started a thread to just fill in the ribs.
3D print shroud guards to fill in the ribs
