jokerio
- Menlo park, Ca
I did a small Up-grade modification to the bike today, can anybody spot it ?
(10 points to the winner)
Agree on the 9mm Brembo, however, not sure if I will route the hose that way.Nice install! This is pretty much what I'd planned to do, as the 9.5/10.5mm piston Clake MC/lever seemed a bit weird to me. If I can find a 9mm, I might go with that instead.
Yea, after looking a little closer at the cheaper one, it says “10” on the bottom, so probably not a 9Thanks much! Nice units.
Pretty sure you can still use a M10x1.0 banjo bolt through a 90 degree banjo fitting into the Brembo master cylinder...@jokerio , @Foss -- Could you please post where you bought the hydraulic line (or the line fittings) that work with the the Stark/Formula LHRB master and the Clake insert?
FYI, the Stark/Formula master cylinder uses a banjo fitting, but the Brembo master cylinder uses a straight screw-in fitting. So, the hydraulic lines must match whatever master cylinder you chose.
Yes, but I was referring to the handlebar master cylinder...
No! They are using a special sleeve with an o-ring that isolates the pressure from the sight glass. You can find details on the CLAKE website.Aren't you guys who have done this awesome mod scared that pressure from the handlebar lever will pop out the sight glas on the "foot master" ???
Thanks for the explanation!No! They are using a special sleeve with an o-ring that isolates the pressure from the sight glass. You can find details on the CLAKE website.
This is actually a good question, because I do have a sight glass on the LHRB, who is to say the pressure could blow this window out, there is no adapter to protect this sight window…Aren't you guys who have done this awesome mod scared that pressure from the handlebar lever will pop out the sight glas on the "foot master" ???
Could you please explain this? Which tools did you use, and which parts did you need to buy?I had the Stark Hydraulic line cut and retapped 10mm with a 45° pitch.
