New mod today - Added Stark LHRB
jokerio
Menlo park, Ca
Added a handlebar mounted rear brake set-up (in addition to the existing foot brake) using the "sleeve insert" from Clake (out of Australia) to modify the OEM Brembo rear Master to except an other brake line (hose) And purchased the handlebar master from Stark that they offer. Check-out the custom install...
If interested, here is the info.. SLR – Pedal Master Cylinder Adapter Kit – CLAKE
Nice install! This is pretty much what I'd planned to do, as the 9.5/10.5mm piston Clake MC/lever seemed a bit weird to me. If I can find a 9mm, I might go with that instead.
Agree on the 9mm Brembo, however, not sure if I will route the hose that way.
I was lucky to find a brand new Brembo 9mm clutch master on ebay for $160 back in August.
Here's a couple possibilities:
Foss
Boca Raton, FL
Just did this mod today, but I had the hydraulic line from Stark cut and retapped with a 45° 10mm head with the pitch in the correct direction. I was able to follow the existing factory hydraulic line path and mount points making it super clean and less likely to snag on anything. Also no drilling or modifications needed going this route. I also maintained the same left hand brake from Stark as well. Looks like it came from the factory with the adjustments I made, extremely hard to notice any difference. I also made the left hand brake a bit more squishy acting as the clutch but still applying the same brake force.
I’ll try and upload some photos later of how I completed the same modification. But thanks to the OP for suggesting this, honestly a great idea.
Foss
Boca Raton, FL
Added the photos, if anyone is interested in seeing how I routed it under the body let me know. I don’t mind taking it off tomorrow at some point.
@jokerio , @Foss -- Could you please post where you bought the hydraulic line (or the line fittings) that work with the the Stark/Formula LHRB master and the Clake insert?
FYI, the Stark/Formula master cylinder uses a banjo fitting, but the Brembo master cylinder uses a straight screw-in fitting. So, the hydraulic lines must match whatever master cylinder you chose.
Pretty sure you can still use a M10x1.0 banjo bolt through a 90 degree banjo fitting into the Brembo master cylinder...
Jocke_D
Sweden
Aren't you guys who have done this awesome mod scared that pressure from the handlebar lever will pop out the sight glas on the "foot master" ???
Jocke_D
Sweden
No! They are using a special sleeve with an o-ring that isolates the pressure from the sight glass. You can find details on the CLAKE website.
Thanks for the explanation!
I saw the sleeve thing after I commented but was still curious since brake fluid can be seen in the pics.
Must be some fluid left and visible in the sight glass unless you clean it out before mounting the sleeve I guess?!?!
I'm ordering one of those sleeves right now !!
Foss
Boca Raton, FL
This is actually a good question, because I do have a sight glass on the LHRB, who is to say the pressure could blow this window out, there is no adapter to protect this sight window…
I had the Stark Hydraulic line cut and retapped 10mm with a 45° pitch.
For people who are me interested in parts used:
SMX1-BR-RWH-02
Rear hand brake Master cylinder assembly
SMX1-BR-RWH-03
Rear hand brake hose
