Rox Handlebar Risers - Cable Length Issues?
Zraaap
AZ, US
Hey All,
First post here. Just purchased a EX yesterday with delivery expected in March.
I've been without a bike for about 6 years (injury + young kids) and am pumped to get back into it.
Anyways, I'm a tall guy and I've always had trouble with the ergonomics of my bikes until I installed the Rox 5" handlebar riser (I know it looks a bit absurd at that height). But the trouble I encountered before was having to reroute wires and cables or even purchase longer/custom cables to accommodate the extra height.
With the wiring of the Starks, does anyone suspect if this will be an issue in terms of not having enough excess wire length to get an extra 5"? I know the wiring is currently routed through the handlebar, which I presume id have to ditch to make this work.
Thanks in advance for any input here!
Hey All,
I suggest you send this question to support@starkfuture.com.
We can guess, but hopefully they will give a good answer.
Zraaap
AZ, US
Fair point. I've watched some of the install videos for the MX model and it seems like it likely won't be doable without wiring extenders and male/female harnesses on each end.
Just a guess though and based on the MX.
I have a buddy with risers on his Varg MX, however, I'm sure they are much less than 5"
Zraaap
AZ, US
Yea the 5" are definitely on the extreme side. I could likely get away with less and be fine.
Was just curious if others had played around with risers and encountered issues or found ways to make it work at all.
It would be pretty easy to extend the wiring on the current model.
But the new EX model will have a sealed new version of the wiring harness, so, it may be more difficult, or you may be able to find the right connectors to make extensions. I doubt if Stark will offer any plug and play solution.
Zraaap
AZ, US
Yea, that's what I was thinking as well. Might have to just custom fab some wiring extenders once I get my hands on the bike and can confirm the connectors and wiring used for the EX.
Agreed that chances are slim that Stark would offer an option here since this is probably a rare 'need' from their customer base.
It would be great to see some pictures/videos of this new EX in-bar routing. After hearing Anton's description, I still cannot imagine how it works!
Zraaap
AZ, US
Once I get it I'll definitely take some photos and upload here. My only guess would be a cutout/hole in the bar itself to enter at the center and then another cutout/hole under the controls.
But that would add a weaker region in the bar of that we're the case. Maybe the bar is just thicker walled to accommodate that.
F451
WA State, USA
I had not heard of the in-bar wiring routing (didn't watch the vid). What do you do if you want to swap the bars out (pretty common mod)?
I wonder if you could just run the wires externally if you went with different bars?
Yes, they actually mentioned in the video that you can swap out the bars and run the wiring externally.
Haven't thought this completely through with the Varg, but one option that might mean less impact to wire harness/cradle/extensions is going with handlebars with a lot of built in rise, rather than adding risers that push up everything. 2" rise is fairly easy to come by, but 5" is a lot. Some of the ATV bars or pitbike bars have a lot of rise, though. One would still need to account for wire length to the controller, and brake lines, but at least you'd not have to extend all the cables from the phone cradle, etc. Again, haven't completely though this through, but was something fairly common with pit bikes, midsize dirtbikes and electric dirtbikes.
Aleksandar13
Uk
Can someone confirm to me that the below bar risers will fit the stark varg ?
rs911
I saw someone who replaced his lower mount with one from a newer KTM on his MX.
It's in one piece, it's perfectly compatible with the stark phone mount (on his MX) and it's more rigid, so the handlebar twists a lot less than stock.
You can choose between 31/36/41/46/51mm height.
The part found on them from the factory is the 36mm and the reference is A48001039036.
The last 2 digits are for the height, 51mm is A48001039051.
Scar also makes this :
I wanted to try the OEM part from my friend's Husky on my EX, but still not done.
Aleksandar13
Uk
Thanks for that , the ktm part numbers are out of stock I’ve just checked . Which leaves me with the bar mount kit but being in Europe it’s not going to work for me cause I’m not paying brexit tax .. do we know the pitch of the bolts and the diameter of the bar so I order some for a ktm in the uk ?
