ktm exc rear wheel fit stark varg?
liyangmin
China
I can not understand quite well after study other related threads.
can anyone simply tell me if the wheel fit or only spacer difference?
Yes, I have a KTM rear wheel on my Varg.
Must use Varg spacers which do not go inside bearings, just against face.
This is what makes me want more standardisation in the industry. Why do bike manufacturers feel the need to change axle size so often.
KTM has 20mm, 22mm, and 25mm axles. The hubs and the bearings are the same, just the spacers and axles are different. This is my experience.
The bearings ID's could not be the same if different axles. If you're right that the hubs are the same then the bearing OD's should be too.
The bearing IDs and ODs are the same. KTM has several different spacers. At least some of the spacers fit inside the bearing as well as against the face of the bearing. The axle then fits inside the spacer. On Stark (and ~maybe~ late model KTM) the spacer has the same ID as the bearing and just sits against the bearing face. So the axle is the maximum diameter possible and matches the bearing and spacer ID.
Hope this helps someone...
Ah I see now. I guess that would be called a sleeve or something between the ID and the axle. Thanks.
