Yes, I have a KTM rear wheel on my Varg.I can not understand quite well after study other related threads.
can anyone simply tell me if the wheel fit or only spacer difference?
All years, AFAIK. Only the spacers and the axles are different.KTM wheels AND spacers do fit. You just need to do your research as to which years/models of KTM axles work with the Varg.
I know ktm increase the dimension of the axles since 2023 (sx/xc bikes ) then 2024 (xcw/exe bikes), before was 20mm now 222mm.All years, AFAIK. Only the spacers and the axles are different.
Try to imagine the unimaginable.The bearings ID's could not be the same if different axles. If you're right that the hubs are the same then the bearing OD's should be too.
Ah I see now. I guess that would be called a sleeve or something between the ID and the axle. Thanks.The bearing IDs and ODs are the same. KTM has several different spacers. At least some of the spacers fit inside the bearing as well as against the face of the bearing. The axle then fits inside the spacer. On Stark (and ~maybe~ late model KTM) the spacer has the same ID as the bearing and just sits against the bearing face. So the axle is the maximum diameter possible and matches the bearing and spacer ID.
Hope this helps someone...
R | Please Help! KTM Freeride exc Brake Light | Play/Small e-Motorcycles | 4 | |
KTM EXC funny review | Videos | 0 | |
KTM 250sxf conversion | DIY e-Motorcycles | 1 |
