Battery teardown, seeking help to reset the battery
heikki
Kankaanpää, Finland
My first post here, and not even sure if it should be on Builds -section or here :) Just got a hint to come the this forum to check if anyone can help.
So I have a build where I'm installing Stark motor to a small Suzuki moped from the 80's. Initially with a 1,5hp 50cc engine :)
I bought a Varg motor with VCU and wiring. According to the seller they are from a running bike. Then I got a battery from another person. He told the battery is broken and he's received another one on warranty. I work with Tesla batteries (repair them) so I though I could take a look inside the Varg battery and see if I could fix that too.
Before I started to open the battery I tested my setup. I had bought all the remaining electrical components form Stark (including the Android phone) and connected everything together. All I get is the red light on the power switch for couple of seconds. I've tried all the tricks I've found online to reboot the system (including holding the power button for a while, re-plugging the battery cables several times etc...) without any luck.
So I opened the pack and found four cells are shorted and completely empty. The pack is 100S4P split into two halves. Total of 400 21700 cells. There's a BMS board on both halves of the pack that monitors the voltages and balances the pack. I though the empty cells might prevent the pack from starting so I bypassed those and made a temporary fix to replace those dead cells with some Tesla cells I had and balanced the voltage to match the other cells of the pack.
I was hoping this would do the trick but I was no lucky, still getting the red light. Now I believe the battery may be in some sort of fault state and would require manual reset, perhaps with some service/diagnostic tool - similar to what car manufacturers use. Also Tesla packs need to be cleared from some latching alerts after repairing them.
I heard some people here have some background information on how these packs have been designed and perhaps could confirm if my assumption is correct? Also I suppose there are no tools available to diagnose and reset the pack/clear the possible alerts.
In my build I need to build my own pack with fewer cells to make them fit on the small moped frame. I was hoping I could have used the Stark BMS and VCU since they are the only ones that I know are able to control the Stark inverter.
Both halves have their own BMS board
Dead, shorted cells.
Cells are glued to the case from the negative end of the cell. This will cool down the cells when the air cools the battery case. I assume the battery might overheat on a long ride under heavy load.
heikki
Kankaanpää, Finland
Just saw the old post from 2019 regarding the Alta pack teardown - a lot of similarities on the pack design!
Thanks for sharing! Good to start building some knowledge on some of these parts that may need some DIY fixing once bikes are out of warranty.
Seeing as you've ordered a phone, I assume you've spoken with Stark. My understanding is that the phones is locked to the bike via the VIN, so this probably includes the phones ability to power the system (motor+battery). Did you buy the motor and VCU from Stark or second hand? If second hand you may need the old owner to transfer ownership to you.
heikki
Kankaanpää, Finland
A whole P group is shorted. That battery half is pretty much useless.
What do you mean with "whole P group"? You mean the four parallel cells? I have isolated those by cutting the cell wires and temporarily replaced with good working cells which are charged and balanced to the same voltage as others. Right now they are external to the battery and wired to the PCB. I'm not aiming to drive with this setup, just see if I can get the motor spinning.
I bought the motor and VCU second hand and they've both been in the same bike and running with it. He had bike with two motors, VCUs and batteries. The previous owner has already sold the bike so he can't transfer ownership. I haven't been able to connect the new phone with the VCU, the phone can't even see Bluetooth of the VCU so I assume VCU is not starting properly.
fsfs
HRV
OK, this time I read more carefully.
AFAIK (since i worked on the software which was a while ago) there is no fault storage or remembering. So if it was just the cells, replacing the P group should do it.
I cannot be sure, but my guess is something wrong the the BMS. That the BMS discharged the P group all the way to zero volts.
heikki
Kankaanpää, Finland
I guess that's possible, if balancing is not working properly. I'll check if it keeps discharging the cells I connected.
Anyway I think my next plan is to try to connect everything to a fully functional pack to see if it starts with that. This way I'd know if the issue is with battery or something else. I don't have that pack myself but the guy who sold me this failed pack has one.
You could try to contact your crazy neighbors at critical.se, doing lots of wild stuff like go kart Varg, very complete videos from the setup and everything, they might be helpful.
heikki
Kankaanpää, Finland
I've actually been in touch with them. They're using all original non-modified motors and batteries from a functional bike(s) so they've not faced similar issues to me. They advised to talk to Stark support. Tried that with no success...
Once cells have gotten past a certain threshold cell voltagewise, its not safe for them to be charged back up to max voltage. They can technically now go thermal or overcharge since internally the chemistry has gone "sour". At zero volts you may as well try and find another clamshell/half. Even with half a pack, the bike might be able to function uptil a certain percentage.
I'm not surprised: their policy about this, which to me looks completely understendable, is that the user should never open a battery.
You've said that you repair EV batteries for a living and I guess you can confirm that opening a Stark Varg battery could result in someone dying.
I am not an admin here and surely it's not my duty, nor my right, to tell you to do things, but I politely suggest that you add a writing in red bold font in the beginning of your first post like "opening a battery like this can be deadly if you are not trained or if you make a mistake".
I would also be grateful if you could contribute to this thread giving some suggestions, since you seem very competent.
heikki
Kankaanpää, Finland
Unfortunately I could not find a way to edit my earlier message. You're correct, I should have highlighted that opening the pack can be lethal if you don't know what you're doing.
You're also correct. If the cells get a lot below 3 volts they are permanently damaged and should not be recharged.
Replacing cells to Stark battery is very difficult and labor intensive. My plan is to build my own pack if I can manage to figure out the BMS side of things. I was hoping to be able to use Stark BMS but so far it's turned out to be very difficult since there's not any diagnostic tools available. I guess I'd need to find a working bike, log some CAN data and try to figure out the correct messaging between the components. Not sure if I have time for all that.
heikki
Kankaanpää, Finland
Today I had a chance to try my motor and VCU with a fully functional battery pack. It started straight away and heard the contractors in the pack to close. When I started yellow LED started flashing and when I put the gear on it started flashing blue and I was able to spin the motor by turning the throttle.
I was not able to connect the phone to the VCU - I guess that's because there's not any VIN associated with my account.
Anyway it's now proven that something is still wrong with the battery I have. Either it's some fault code that needs to be cleared or then some kind of electrical issue on the pack. Need to keep digging. Perhaps I need to get a CAN logger and start diving into the communication between the battery and the VCU.
heikki
Kankaanpää, Finland
Found more bad cells from my pack. After "replacing" them I got my setup to power on and motor spinning! So it seems after all there's no latching alerts on BMS as @fsfs suggested. This is a big step for my project, now I can really start focusing on mounting the motor to my bike.
I can't connect to the phone but I guess I can live with it.
Interesting enough, all the failed cells are on pretty much the same area on both halves of the battery - on the lower section which is covered with the shield. I was wondering if that could cause some soft of overheating issue which ruins the cells :unsure:
krullete
Spain
Hi, i am trying to completely remove the cells from the battery, dows anyone has an idea of a video of someone doing It? Thank you.
I have taken the cells out of the Stark battery. As mentioned before THIS COULD BE DANGEROUS,
OPENING A BATTERY LIKE THIS CAN BE DEADLY, IF YOU ARE NOT TRAINED, OR IF YOU MAKE A MISTAKE...WORK ON THIS AT YOUR OWN RISK
I worked for 50 Years in the XRAY / NUCLEAR and MRI Medical industry, on the technical side, and have a lot of experience on High Voltage XRAY, (120-150KV), and High current. But this battery is just as dangerous. I videoed only the pulling out the individual cells, and I will share it. But the initial tear down needs to be done slowly and carefully. The battery pack could have between 300-420V at about 180A, this is dangerous. You cannot measure it from the outside, there are contactors inside, but once you open it up, and you splits the pack in half, each side could have 150-210V. I pealed off the layer in the pictures above until I got to the green circuit board. Then I cut all the Fusible links. Now the battery is a little safer. But a single cell can cause a fire. so always be aware of that fact.
In the YouTube, I go about the extracting of the individual cells. They are glued into the base unit, and thus isolated from each other. By cutting the grey wrap on the cell , and making sure it is loose in the back, you can pull the cell out with very minimal damage to each cell. There is a plastic structure around the top of all the cells, and that is what I break out first with the metal chisel. Then use the plastic wedges to wiggle it, and then the TOOTH extractor to pull it out. I only damaged a few cells in the very beginning, and they are bend but still seem to be OK, but I am not using them.
Here is the YouTube of me extracting them. Use at your own risk.
I am just finishing up a 20S12P pack to fit into my electric 2022 KTM 250SXF . I used 240 cells out of the Stark. I used other cells on the KTM Duke project. There is a YouTube on that first ride on my channel also.
