CAN connection between bike and charger
bennymic
Fl
Has anyone tried to reverse engineer it? If it's standard like NACS you could probably just wire up an adapter and charge from tesla chargers. My delivery date is not till August otherwise I would look into it...
rs911
I thought about reverse engineering it, but first I'm onto something else, a lighter and more portable charger.
I worked on something similar with some contacts in my activity of tuning cars and swapping engines/ECUs with different CANbus protocols.
While an automotive DC charger would be a natural choice, the connectors on those are pretty big already. So even if you figure out the CAN part, the adapter and cable would still be quite bulky as I don't think you could take a lot of short cuts with the voltage and amperage involved.
bennymic
Fl
The part that sticks into the vehicle is a larger "diameter". That determines the space required on the vehicle.
Bosch
On the charger cable Pin A=CanL Pin B = CanH
On the signal Cable Pin A=CanL Pin B = CanH
I have attached the Can 1000 Protocol.
I found this faultfinding the charger, not reverse engineering it.
I did find a resistor across the CanL/CanH at the signal plug, so this may be a dedicated Can just for the charge cct.
  • EVPT CAN Protocol 1000.pdf
