Ordering next week, do I get a 60hp or 80hp version?
pollenface
Perth, Australia
I consider myself an amateur by modern standards, I've been riding irregularly for the past few years after having started a family. The stark appeals to me being a low maintenance option.
It's $1000aud difference between the 60hp and 80hp versions. I'm about 90kg in gear (198lbs) 90% of my riding is slowish single trails, a little bit of sand, occasional hills with rocks strewn everywhere. I'm sure I would be happy with 60hp but am tempted to get the 80hp just to "see what it's like"
If you want to stick to dirt, go with the 60hp.
I've had my 80hp EX for 1 month and I'm glad I got the 80hp because I do both street and dirt.
I'm even going to order a set of supermoto wheels this month :)
the 80 actually makes 63hp
i ride with the alpha 80 set on the phones 60 anyway
consider resale as well as what else it may alter
delivery from stark itself is nothing but a cluster f**K
local dealer if they have what you want in stock
get rid of those stupid tubes before it leaves there shop
Hi my friend, i was hesitating between the 60 or 80, but since I found out that if I chose the 60 I could later upgrade to the 80 by paying the 1000€ later, I didn't think twice and chose the 60. I can assure you that it is totally enough power for the road and for offroad. The acceleration is incredible, at 60 hp, even at 45, the front wheel lifts off if you turn the grip too much, you have to be going at least 50 or 60 km/h so that it doesn't lift you up and yo need to lean forward. On dirt, I usually go with 25/30 hp and it is more than enough, even in technical sections I lower it to 15 hp.
Do whatever you want but if you are willing to pay extra for the 80hp version just do it later, try 60 for sometime and see...
I am with @markhamr. I had the 80 with an 18" rear and foot brake. My bike was near perfect for me. Absolutely loved it and is what I am going to replace my stolen bike with again.
BTW the only aftermarkets I added were Acerbis handguards, IRC heavy duty tubes, and an AXP extended skid plate.
Also agree with @Beagle if you have a good dealer strongly recommend if the price is close. The dealer I used smoothed a lot of the hiccups that the direct ship folks mention.
@pollenface do not forget to get a referral from a Stark Rider before you go to the dealer or order don’t wanna pass up the $300 in parts credit.
I bought the 80 about 2 months ago...I still haven't gotten the courage to put it past 60.
I recommend an open field or somewhere that you can open it up safely. Tight trails with a lot of trees is not recommended first time. The throttle is graduated so you won't loop out with more HP unless you blast wide open with great traction, otherwise given the weight distribution of the machine you will more likely dig a trench.
If I order the 60 hp version I heard I can upgrade power later I just want to make sure I can get all the extra riding modes and set up through the app I hope .
The recommendation is turn it down and get after the throttle harder anyway
also running the thing full noise will burn it out
I'm going to turn mine down to 50 next time out
I do like 60 for ease of carrying the front wheel and the throttle
suits me more like that
70 80 is for skylarking or drag racing / supermotard.
I can just get it hooking up from a stand at 60 on the dirt
I'll echo the above. Somehow the Varg on 40hp is way faster than my FX350 and that thing is not slow. I rode it in 60 for a minute and have no use for that on the trails I ride. Maybe if your terrain is sugar sand it would be useful, but on dirt it's just ridiculous.
Gnarly hills where there is often just one tire line --and where jumping out of the line is all you got-- and you need the HP to hit it where no one else had just to save yourself. That will make you very happy you have 60 or even 80 to use. Otherwise you get to practice using crawl and reverse to reposition it to go back down cuz there is no way to tackle that beast from the middle.
I have an 80 but never tried more then 50hp 😅😅… it’s to much for dirt riding , I know ride in 45hp most of the time unless it’s very wet !! Might as well dump the money into the suspension to make it perfect for you and some step pegs… that’s what I did . Bloody brilliant
if you're gonna be a bear be a grizzly. spend the money. you will probably never use 80hp but you have it. do you want to spend your time explaining to fools why 60 is already overkill or why your bike is just as good to folks who bought the 80. listen man I bought a 2022 zero sr, it looks just like their srf but costs less and doesn't have as many features but is totally upgradeable to srf level. I figured I don't need gps, heated grips, reverse or faster charging but the power upgrade sounded good. the bike is pretty quick and I don't know if I am going to spend 2 grand to get more power or not. I really need to test ride or ride with a faster zero to see if it is worth it. point is at this point I wish I had bought the srf because not knowing is killing me. learn from my mistake and get the biggest, baddest even if you don't ever use it for more than bragging rights.
