Alternative License Plate Mounting Ideas for the EX.
electricsheep
NM
Has anyone figured out a good place to the plate to mount to the bike and not get torn off in the first UPD or loop out? I'm in the USA so our plates are much smaller than say the UK.
I'm leaning on bending it to fit the rear fender lengthways and mount it there.
AbnormalWrench
Seattle, WA, USA
I wanted my plate to also act as a mud guard. I did the same thing on my KTM Freeride, the stock rear mud guard didn't offer enough protection, and I ended up with mud all over my back and in my hair. I used 2 layers of ABS plastic with the stock plate bracket sandwiched in there. It should be strong enough to take a fall or a branch when off roading. I did something similar on my DRZ400 but found you needed a lot of reinforcement to counter the engine vibration. I assume that won't be a problem here. Hopefully?1748491287117.png
svtride
DEETROIT
I wanted my plate to also act as a mud guard. I did the same thing on my KTM Freeride, the stock rear mud guard didn't offer enough protection, and I ended up with mud all over my back and in my hair. I used 2 layers of ABS plastic with the stock plate bracket sandwiched in there. It should be strong enough to take a fall or a branch when off roading. I did something similar on my DRZ400 but found you needed a lot of reinforcement to counter the engine vibration. I assume that won't be a problem here. Hopefully?View attachment 13889
Just got a ticket last week by a local DNR constable, trail side, for not having the plate oriented correctly…just saying you may have like minded powleece in your neighborhood...
WoodsWeapon
I used this on my 500 and will be transferring it over to EX, it’s not the cheapest option, but it works well and I have no interest in getting sliced open from a rigid mounted plate.
AbnormalWrench
Seattle, WA, USA
We don't really have any enforcement that I've seen. I've ran this same setup on other bikes for years, never had a problem
First crash at the MX track and the plastic piece i was using to hold my plate broke off. It's a pretty vulnerable part of the bike, so not sure how they could design it better.
Jasperfield
WNC
I had my print shop make a full color decal of my plate. It was then mounted on the underside of the fender up near the front of the tire. I'm in Western North Carolina and have not had any problems yet.
electricsheep
NM
That's not a bad idea! Doesn't sound legal at all, but it might fly in a pinch.
vic321
No need for the ugly extension. Shape the plastic end of the VARG (with the three holes) downward with hot air pistol, attach the license plate, and you're done. In EU a light motorcycle doesn't need indicators. The brake light, license plate light, and taillight are already provided by the already mounted taillight. It costs €0. With a HotSwop Pro (€60), you can make the license plate removable if necessary.
Julo EX
Not in every country, in France im pretty sure you need to have separate blinkers (not like the varg has)
