Looking for Higo Connector-Cable Knowledge / Experience from the Collective
svtride
DEETROIT
First off, I have no direct experience with Higo connectors/cabling and am looking for advice from the collective here on sourcing and/or self-fabricating (if even possible as they are over-molded) cable assembles.
That said, this is what I am conceptualizing:
In looking for a solution for my EX toward powering a GPS, I am looking for a power tap means to run my GPS, 12Vdc, a few milliamps at most. I have researched a bit and understand the headlight is 12Vdc powered. I have also ID’ed the 5 pin Higo connectors (M & F), I think, that Stark has selected to connect the headlight/turn signal cable to the bike’s charging module.
Z511BG P Male https://www.higoconnector.com/en/e-bike-connector/z511bgp00ft1000
Z511BM P Female https://higoconnector.digitaledoeners.be/en/e-bike-connector/z511bmp00ft1000
Listed under their E-Bike connector series.
I realize the links are for a cable assy, but the connector referenced is key for me.
I am envisioning a splitter type patch cable perhaps 200 to 300mm in overall length that one leg will connect between the headlight/turn signal connector (use all 5 circuits) and its mating receptacle on the backside of the bike’s charging module. The second leg would split off and use as a 12Vdc aux power source. That source would be one of the larger pins, I suspect, that carry the headlight current. The Higo connector specs state the 2 larger pins are rated to 20 amps, the 3 smaller pins are 2 amp rated. I would only use the 2 large pins as I suspect 1 is a common ground and other headlight positive. The other 3 used for turn signals, and high beam control signal. I’d need to do some ohmmeter pin out research to confirm, but as the cabling is all sealed, having a break-out harness to test things would be beneficial.
Does anyone have comments or suggestions as to how I could proceed?
I do have an email into Higo directly asking this exact scenario. Am awaiting response which I will share here if they reply.
Thanks.
EDIT later in day: I found an alternate way to access aux power from Stark EX. I'm no longer pursuing Higo splitter.
The European EX bikes come with a Higo to Euro5 OBDII (red connector, just google) adapter cable that plugs into a 6-pin Higo connector that sits above the battery. The Euro5 OBDII connectors should be easier to source than the Higo ones and there you'll find +12V and ground which should easily power the GPS. If the US bikes don't come with that adapter cable you could probably order one from Stark. Just an idea!
svtride
DEETROIT
Thanks Michael for the OBDII connector tip. This lead me to strip the plastics off my EX (purchased via dealer) for the first time and I was able to find the round HIGO OBDII . I did not receive an adapter cable with bike at purchase. [I know now what it looks like having Googled it. The one end of OBDII looks similar to the service port connectors on my KTMs but requires a HIGO adapter for opposite end to link to the Stark.] BUT this effort lead me to examine the entire electrical harness and my discovery that the rad fan and water plug had non-HIGO type connectors. I went about thinking that Stark had use Higo connectors everywhere. My bad. I knew the water pump ran whenever bike is powered up so I now had an easy source to tap 12Vdc, milliamp GPS power from. Harness built and installed, GPS powers up, and bike functions as it always has.
Thank you for planting the seed.
Hinkelstein
View attachment 14089View attachment 14088
@svtride Hi, great Idea to hook into the waterpump plug. Did you identify the type of the plug needed to build a harness? Best Peter
BTW: There is a (german) source for the black six pin connectors: ET Startseite
svtride
DEETROIT
No. I disassembled the water pump connector (removed terminals from plastic housing) and spliced into existing leads, heat shrunk splice then reassembled connector. Harness I built was just a 2 amp fused +/- circuit up to handlebar to the powered GPS mount.
I see Stark has a pigtail for the OBDII available…but as I now have a power source, I don’t know what I’d need the OBDII connector for at this time.
Hinkelstein
I contacted them asking for the purpose of the cable, they said they must provide an OBD Port due to regulations in some countries.
finn
Aachen
Thank you so much. You saved me a lot of web search ...
Has anyone figured out a source for the Higo Z511BG P Male connector with a cable and a blank end?
Brokein2
Morton, Wa
In an effort to shut off the headlight, I contacted the Higo manufacturer and the minimum qty to purchase is 300...so I guess that isn't going to happen easily. I then tried contacting other companies that produce products with Higo connectors to see if someone could produce a cable with both male and female Z511BG ends with a switch built in and got no response back.
joeblack21
Europe
Also looking for a solution to turn off both headlight and rear light on the EX, contacted Stark on IG and they said they might consider it to be done on the app in the future. No luck getting a hold of male and female Higo connectors, Stark doesnt offer them either, this was their response : "Currently, we do not offer the option to purchase individual HIGO connector plugs or extensions for the Stark VARG EX's headlight. Our spare parts catalog focuses on providing components that are essential for the maintenance and operation of the bike, and specific connectors like the HIGO plugs are not available as standalone items."
apeman426
New york
You could buy a whole new switch from Stark for $89, is there a way to use that switch? Does it have the correct ends? Would it be possible to repurpose the kill switch on the throttle side of the handlebar?
finn
Aachen
No, it's only a button which is switched by software and uses a Higo Micro M connector plugged in under the docking station.
