Varg ex red light
tymck7
Utah, US
I’ve been on about 4 real rides with my varg ex. The first ride was dirt, and I had no problems except we ran into snow.. 😂
Second ride I had switched to SM tires/wheels and 15t front sprocket/42t rear sprocket, and rode it on some errands near my house on roads and highways. Chain was a little looser than ideal because the rear sprocket was so small that i couldn’t scoot the wheel far enough back, but it wasn’t so loose i was too worried about derailing or anything. As I got up to highway speeds (75mph) the bike stopped responding and gave me a red solid LED. I coasted to a stop, turned the bike off and back on and tried it again. A quarter mile later it did it again. Restarted and went again and it died a third time 500 feet short of my driveway. It’s embarrassing to be pushing your dead, brand new motorcycle down the road, especially when it’s electric…
I previously owned a varg mx, and it did the red light thing once or twice when I went full throttle for a few minutes at a time (80mph ish), so I didn’t think too much of this issue, although i thought it was extremely lame that such a powerful and torquey bike can’t go highway speeds for any length of time reliably without overheating or whatever is going on.
Anyways, my third ride was yesterday and i put the dirt wheels back on, 15t front sprocket left on for easier conversion back and forth from street to dirt and back, (15t front and 48t rear for the dirt setup) (mx was 14t/47t, so i figure there shouldn’t be a problem with this, although i had to grind down the front sprocket guard a little bit to get the 15t to not rub). Third ride we went a few easy miles on dirt and then the red light issue happened. Kept going and it happened again. And again. And again. Probably at least 10 times in 10 miles. At its worst i couldn’t go 500 feet without it dying. It predominantly occurred while climbing, fast or slow didn’t matter, never got into anything steep just moderate climbs. Funny thing is, home was almost entirely down hill, and it only died once. Even more perplexing was that there is one long section of uphill highway ride on the way home, 50mph, and it didn’t die. I thought for sure it would. Red light did not correspond to throttle position or any pattern i could discern (riding hard or taking it easy, it would die either way).
Anyways, checked the chain and it was a little tighter than it should be (2 fingers versus 3), so i loosened it, set it perfectly, pumped the tires up a little to reduce rolling resistance (operating under the theory that this was some kind of torque issue due to a tight chain/larger front sprocket/etc), and emailed stark to try to get help.
4th ride this morning we got maybe 3 minutes in and it red lighted. Then 1000 ft later it did it again. And again. And again. VERY easy riding, no way this is a torque, chain or sprocket issue. And it’s getting worse with each ride. Maybe went 2 miles total and it died at least 10 times. Struggled to even get home. Died while easy climbing. Died while basically coasting down hill. Died with hard throttle, died with light throttle. I can’t discern a pattern other than that it’s unusable and getting worse. Sorry all for the novel, I’m waiting for stark to respond, but I’m here on vacation for the next week, was hoping to ride the whole time (as was my dad I’m riding with). Looks like the varg might end up ruinning the trip…
It may be a temperature sensor triggering it. I would check the coolant fluid. Top up, remove any air, or replace entirely.
tymck7
Utah, US
Thanks for the thought. That’s what I initially thought as well but the motor/battery isn’t even hardly warm by the time it shuts down, so i figured it wasn’t ACTUALLY overheating, just acting like it. Stark got back to me and say they think it’s a powertrain issue, and that i have to take it to a dealer. So I’ll try that first i guess…
AbnormalWrench
Seattle, WA, USA
Well, just because I went through something similar, check the wire connectors at the phone charger. Since these connectors do not lock, they can slip down and have a crappy connection. Make sure they are all fully pushed in. I really don't like that about these connectors, they don't lock and it isn't obvious when they are fully pushed in.
tymck7
Utah, US
Could be one of a few things or more than one
so i would take it to the dealer.
Please report back as it helps others sort issues
they may have.
Took to local dealer on Saturday, sounds like they have had to replace a powertrain or two previously, so we’ll see i guess. Dealer says it will be 3-4 weeks until bike is done.
tymck7
Utah, US
Good thought. I didn’t check that before dropping the bike off with the dealer, but putting the bike together when i first got it, i did think the same thing. Wish those connectors gave you some indication that they were all the way….connected. Throttle seemed to work consistently and flawlessly for 10-15 minutes at a time and then would stop altogether, and then turning back off and back on, would run flawlessly again, so i figured its not likely an electrical connection issue
@tymck7 Did Stark log into your bike and troubleshoot or did they say powertrain just from your explanation? I wonder if the dealership even checked the connectors as @AbnormalWrench suggested and test or if they just go ahead and follow Stark's troubleshoot.
No harm in getting a new drivetrain I guess, but I still hate to lose 3-4 weeks of riding time in the summer.
tymck7
Utah, US
I'm not sure what the dealership plans to do, but from the sound of it, Stark doesn't seem to have logged into my bike (at least not that I was notified of), and the dealership sounds like they are just going to proceed with Stark's recommendation with the replacing the powertrain. I previously owned a Varg MX, and when I first got it, it wouldn't charge. Stark handled that situation differently, i.e. they logged into my bike and then sent me a replacement for the charger plugin on the bike, which didn't fix the issue, and then sent me a new charger. Charger was the problem. ...This time, they just seemed to jump straight to drivetrain, so it sounded to me like this is not a unique problem. We'll see if that fixes the issue, but I agree, I hate losing my bike for a month in the summer...
Jake
Washington State
Similar Issue with my Varg EX. Mine was shutting down (red LED) mostly when I turned left, then all the time. I tracked my problem down to a broken wire inside the wire bundle that comes from the wireless charging Module. The plug is secured to the frame and the wire bends back and forth when you turn until in it brakes
Brokein2
Morton, Wa
That plastic piece that secures the wires to the right side of the frame is the cause...remove it and use some zip ties in it's place and let the wires have more freedom to move and they won't disconnect anymore when you turn.
tymck7
Utah, US
The amount of start up problems
and other issues this bike has had
points directly at the company,
being second rate or worse.
I don't think that's necessarily true. It's a new company with a brand new type of product, I signed up for it knowing there will be growing pains. As long as they can deliver me a correctly working bike, I'm thrilled with it. If not, that's another story, but I'm giving them the benefit of the doubt. This thing's fun
markhamr
blaxlands creek australia
Lets face it.
It is extremely hard to get a bike into production
and market it successfully.
I do think that stark needs to show improvement
both product and company behaviour,
as it goes to encourage less negative press
and grow in the future.
Jake
Washington State
Totally Agree with markhamr, new company, new technology and totally awesome fun like no ICE bike can deliver, I knew what I signed up for. With a two year warranty, great engineering and good (albeit a little slow) customer support, I believe they will work out the bugs.
