I don't run out of battery . I ride my bike in mostly trail, slow gnarl, and hard enduro typically 4 hours or less. I am not a fast MX track guy like you anymore.Are you running out of battery? I'm not wanting to compromise my riding style to recharge a battery I have yet to drain. I think some have proven the Regen to work going downhill, but I want to be in control of the brakes and momentum. Most riders are off throttle way more than on throttle. If you shut the throttle with Regen slowing you 20 ft before the corner, you have to reapply the throttle to make up that 20 ft. You should try it, it's more like a 2 stroke. With the chassis reacting to throttle vs Regen or braking it makes it more consistent and settle without the on off on off.
Nothing fast about my pace these days, but I do ride track and trails and do most of the jumps that aren’t too scaryI don't run out of battery . I ride my bike in mostly trail, slow gnarl, and hard enduro typically 4 hours or less. I am not a fast MX track guy like you anymore.![]()
Agreed, it was more a comment about range.Yeah but the pro's can swap battery's in between 2 races. 99%+ of the amatures can't.
But at least in the Dutch format it's plenty doable.
Hurray for extension cords!absolute b/s erwin
If you like ill bet my cattle station the bike is WAY OVERWEIGHT
as against the 118 kgs advertised weight.
Anybody else weighed there bike????
I would change battery;s or another bike even.
You can not change bikes and i do not have a team to change my battery during lunch.
As i said to the dealer ,
If the bikes any good I will be back for another one
IT IS NOT.
Yes beagle it is the format that is the problem.
I would need it to be over 2 days so i can charge the thing.
I have moved to a 14th front sprocket
The bike seems way better and I will range test it in the weekend.
That will not help the 13 1/2 pounds 6.2 kgs it is overweight.
Are you talking about the FIM limit erwin(123kgs) or the 124.2 kgs mine weighs
as opposed to the 118 kg advertised weight>
dirtbikechannel.com
According to that website all of those OEM's are filthy lyers.It is indeed a couple kilos extra compared to advertised, 120.4 kg instead of 118 kg.
Dirt Bike Weight Comparison - with Examples
How much does a dirt bike weigh, ready to ride? Comparing modern enduro bikes weight. Each dirt bike is weighed with a full tank of fuel, full fluids, and with no aftermarket partsdirtbikechannel.com
I'll say a couple extra kilos is nothing out of the ordinary but you seem so obsessed about it, why don't you compare all the measured weights of motorcycles on this page with their advertised weight and come back with a nice spreadsheet?
