Foss
Stark SME
- Vestal, NY
Hey guys, as the title states, just seeing if the KTM XTRIG 22mm setup will work with the Varg? My only thing is the mounting points for the fenders.
Sorry, lots on our plate! Bar mounts and steering stem are complete, prototyping clamps now.Yea there may be a lot of parting together to get it to work. Billy at Luxon is taking forever![]()
@Luxon MX , you have any projection when these triple clamps will be available? Also A-Kit compatible for KYB?Sorry, lots on our plate! Bar mounts and steering stem are complete, prototyping clamps now.
Thanks!
Just checking in with you to see if any progress has been made with these triple clamps, thanks!Nothing firm yet, 1-2 months or so. And unless your A-kit is really old, it is the same size as standard KYB, so no issues there!
Not yet, unfortunately. We've been slammed the last few months. Hoping to get some "free" time once supercross starts up to get these clamps going!Just checking in with you to see if any progress has been made with these triple clamps, thanks!
Hate to bother you, but..... Luxson Stark clamps still in progress?Not yet, unfortunately. We've been slammed the last few months. Hoping to get some "free" time once supercross starts up to get these clamps going!
Sorry, I never got an alert about your reply. I just replied on the other thread, though:Hate to bother you, but..... Luxson Stark clamps still in progress?
hi - do you know if the WP Stanchoins have the same diameter as KYBs? (they both have 48mm lowers), the lower headset bearing is the same on the KTM and on the Stark? how did you fit the fender and the number plate - would love to have some more details - best regards chris
They are not the same diameter as KYB. Stock clamps will not work. I did custom mounts for the fender and front number plate. There are a few different geometries that I've seen for x trig clamps, I have one of each. I did a weld on solution on one bike, and 3d printed bolt on parts for the other. This is the latest build I didhi - do you know if the WP Stanchoins have the same diameter as KYBs? (they both have 48mm lowers), the lower headset bearing is the same on the KTM and on the Stark? how did you fit the fender and the number plate - would love to have some more details - best regards chris
No, they are different. But you can use KYB outer tubes with standard WP 48mm lower tubes and cartridges. Xact Pro (ConeValve) cartridges will not fit though - different thread pitch.do you know if the WP Stanchoins have the same diameter as KYBs?
thx for the info!!The lower clamp is the same. The upper is 1mm wider from WP.
thx for the info!!No, they are different. But you can use KYB outer tubes with standard WP 48mm lower tubes and cartridges. Xact Pro (ConeValve) cartridges will not fit though - different thread pitch.
Sorry, the other way round!thx for the info!!
